Author Topic: Indicators still work when the ignitions off ?????  (Read 1014 times)
Offline Uruk Hai
« on: 29 January 2007, 16:23 »
As above when the ignition is off the indicators work, the parking light for the same side comes on as well ? (the green turn signal LED doesn't come )  I'm baffled by this one and would appreciate any help, thanks  :smiley:
sacvwgolf
Re: Indicators still work when the ignitions off ?????
« Reply #1 on: 29 January 2007, 17:21 »
i thought that was normal, well the indicators bit as the hazards work when the ignition off i don't know is this is the case with mine?
Offline Mr Blue
« Reply #2 on: 29 January 2007, 17:22 »
Do you mean the indicators keep blinking when ignition is off?  :rolleyes:
If its just the parking light its supposed to do that mate.  If your car is parked sticking out too far on the road then you use this for safety. (well i use it for things like this anyway)
Offline Uruk Hai
« Reply #3 on: 29 January 2007, 17:27 »
When the ignition is off the indicators still work when I move the stalk up or down and at the same time the parking light for that side is on, if I pull in and turn the car off, take the keys out and then put the left parking light on the indicator's on the same side flash as well (and I don't mean the hazards)
Offline systemseiko
« Reply #4 on: 29 January 2007, 20:25 »
Is there an after market alarm fitted and if so when? could be dodgy wiring from the indicator stalk during fitment?
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
Offline Uruk Hai
« Reply #5 on: 29 January 2007, 21:03 »
I did have an old alarm removed because it no longer worked but wouldn't that have been connected up via the hazard warning circuit ?
Offline Uruk Hai
« Reply #6 on: 07 February 2007, 20:02 »
Anyone ? :undecided:
