Author Topic: Mk3 steering off centre  (Read 1755 times)
Offline Camboose
« on: 29 January 2007, 16:14 »
I have a mk3 gti 16v. I have just changed a the front nearside wheel bearing. Now the steering wheel is off centre when the wheels are straight. I had the tracking done and this hasn't solved the problem. Is there a way to solve this? Cheers
Offline monkeyalan
Re: Mk3 steering off centre
« Reply #1 on: 29 January 2007, 17:39 »
take it to somewhere else and get it done properly.
sounds like bodge job.
been there.  :angry:
they should centre the steering wheel and steady it with a brace , then do the tracking.
Offline Camboose
« Reply #2 on: 29 January 2007, 17:48 »
Can't I just adjust the steering wheel, someone told me I could do that? Or will I get excessive tyre wear etc?
Offline Camboose
« Reply #3 on: 29 January 2007, 18:08 »
Forgot to mention my other problem. When I am doing a 3 point turn, or steering very tight, the car makes a grinding noise. On the same side as the wheel bearing replacement. Had a look and I can't see anything obvious that should be rubbing. At high speed tight corners with a lot of weight in the car it also makes a high pitched shriek sound. As if metal is grinding. Any ideas???? Cheers
Offline robster23
  • Now a VW Fox Owner.
« Reply #4 on: 30 January 2007, 00:51 »
For the scraping problem - if the tracking is done properly it will centre the wheel and also stop that problem - due to the set up being off set to one side I should think.
The high pitch whining could be the bearing bedding in, it could also be the bearing not fitted well, although I think the noise would happen all the time and get worse when turning against that wheel - more car weight on it.
Take it back and say OI! It's not doing what its supposed to!  :angry:
It's urban right? That means it must be tougher, obviously.... ;-)
Offline garfayliu
« Reply #5 on: 30 January 2007, 09:17 »
the steering getting tight could be the bellow thing becoming twisted, happened to me once when I got local slow-fit to do tracking, wheels pointed straight, but I only got  1 turn lock right and about 3 turns left, steering was tight, ended up ripping the bellow and doing tracking myself after borrowing some dunlop gauges.
Offline monkeyalan
« Reply #6 on: 30 January 2007, 12:08 »
same thing happend to me, different bunch of twits tho'. (challenger tyres , rutland rd, sheffield..AVOID LIKE THE PLAGUE!)
only in my case they also managed to burn through both CV boots and snap part of the casing on the rack.  :huh:
I reluctantly let them replace everything, free of course , but got someone i trust to give it a once over when it was fixed.
« Reply #7 on: 30 January 2007, 16:38 »
did you mark the position of the hub->strut bolts before you removed the hub, and then refit them in the same place? If not the camber will be out which will make your wheel sit off centre.
