Author Topic: lowering mk3  (Read 2105 times)
Offline big mike
lowering mk3
« on: 27 January 2007, 16:56 »
ive just bought a mk3 gti and would like it lowered. its only for looks, probably 30mm as it still needs to be usable.. can anyone recomend a set of springs.. noticed j.tec and another manufacturer from germany with sets on ebay,,can anyone tell me about this particular ones
cheers,,mike
Offline monkeyalan
Re: lowering mk3
« Reply #1 on: 27 January 2007, 17:42 »
Eibach every time. expensive but well worth it.
Offline nicholasp
Re: lowering mk3
« Reply #2 on: 27 January 2007, 18:30 »
ive read that you should change the shocks as well, otherwise it will bottom out.
Offline gtitdi
Re: lowering mk3
« Reply #3 on: 27 January 2007, 18:43 »
i've just got a set of eibach springs and read that it would be advisable to get some shocks as well so I got some Boge Turbo Gas shocks quite cheap from gsfcarparts
Offline stomper
Re: lowering mk3
« Reply #4 on: 27 January 2007, 18:54 »
Eibach springs are superb by all accounts, can be used with original dampers as long as they're in good condition.
Will drop about 30mm.
2003 Black Magic Bora Sport 1.8T (180)
AMD remap
Milltek Cat-back exhaust
18" BBS RC's
Eibach 30mm Springs with Boge Shocks
Front and Rear V6 4Motion Valances
Offline monkeyalan
Re: lowering mk3
« Reply #5 on: 27 January 2007, 20:37 »
Ive had them on my mk3 for 2 years now and the standard shocks are still fine.
Not bad considering I live in pothole city , speedbumpshire.  :laugh:  :cry:
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
Re: lowering mk3
« Reply #6 on: 27 January 2007, 21:23 »
Yep we've got Eibachs on my brother's MK3, they've actually dropped almost 40mm and the ride is fantastic.  Standard shocks - boge turbos and monroes
I think as long you go with progressively wound springs, you should be ok.
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline golfpro
  • If in doubt, pay someone else to do it!
Re: lowering mk3
« Reply #7 on: 28 January 2007, 08:41 »
I always think that if you lower it then its worth doin shocks at the same time as the springs. like is said above though, eibach's are very good
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
Offline yabbie
Re: lowering mk3
« Reply #8 on: 28 January 2007, 08:57 »
had mine lowered last week ive got a bilstien sprintline kit on mine dropped it 35mm and it amazing handling in 10 times better only problem i had was when the car is loaded it rubbed on the arches so i had to do a bit of grinding and now its sweet oh the kit cost me just over £400
Offline big mike
Re: lowering mk3
« Reply #9 on: 28 January 2007, 12:21 »
the car has new shocks fitted, i only want to lower it for looks and as always money is an isue so this is why i was hoping to just do yhe spring kit, how much are the eibach kits?
