Golf mk2
Rattling from behind speedo
Topic: Rattling from behind speedo (Read 1396 times)
Uruk Hai
24 January 2007, 18:44 »
Driving to work yesterday I noticed a rattling/vibration that seemed to be coming from behind the speedo, the noise seemed to start at about 40 mph and got louder the faster I went. By the time I got to work I could no longer hear it and it was fine coming home, this morning it did the same again. I'm wondering if it could be the speedo drive but I'm not sure, does anyone have any ideas ? and how easy/hard is it to change the speedo cable. Any help or advice appreciated, thanks
shaft69
Re: Rattling from behind speedo
24 January 2007, 20:42 »
It seems like it's speedo cable mine does the same, But not changing mine till i sell the car.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Ktuludays
GTI forum regular
24 January 2007, 21:03 »
mine did the same till i filled it with grease. it's been fine ever since.
<br /><br />What don\'t kill ya, makes you more strong!
Uruk Hai
24 January 2007, 21:12 »
How did you manage to get to it to fill it with grease as it seems a bit concealed (I know I'm being thick but I've never done a speedo cable before) and thanks for the advice
Ben Lessani
The poor mans MK2 Haynes author
25 January 2007, 00:19 »
its a bit of a pig to get into when the clocks are in place, but if you remove them all, its not too bad, still burried a little in the dash
NewStu
Here all the time
25 January 2007, 10:29 »
Mine did this when i cam loose a little and was worse on cold mornings.
Uruk Hai
Reply #6 on:
25 January 2007, 18:33 »
Mines only been doing this since the cold mornings ?
Ktuludays
GTI forum regular
Reply #7 on:
26 January 2007, 13:34 »
remove the stereo and fascia panels including all the switches. undo the 8 or so screws to do this.
undo the two screws holding the clocks in, then remove them.
cable will be hanging free now.
pack it with grease and reassemble the whole lot.
job done.
1 hours work tops!
Uruk Hai
Reply #8 on:
26 January 2007, 13:44 »
Cheers mate appreciate the help
Golf mk2
