The garage
putting in gear
Topic: putting in gear (Read 2020 times)
Gt-tdi
putting in gear
21 January 2004, 20:56 »
hello peeps. my mk4 i sometimes find it hard to put into (usually 1st) gear. it sometimes feels so stiff. reverse isnt any easier but the clutch doesnt slip. would it still mean clutch even though it doesnt slip or something else?
TDI = economy and FAST!!
Rob
Re:putting in gear
21 January 2004, 22:23 »
just a thought but could be worn bushes on gear linkage.
im no expert
jedi16v
GTI forum regular
Re:putting in gear
21 January 2004, 22:27 »
how many miles have you done?
richandhazel
Global Moderator
Forum addict
Re:putting in gear
21 January 2004, 22:32 »
Have you tried putting it in gear, but instead of using force, keeping gentle pressure on the gearstick and letting the clutch out at the same time? You should find that as you let the clutch out, it will pop into gear really easily
Last Edit: 21 January 2004, 22:33 by richandhazel
Gt-tdi
Re:putting in gear
23 January 2004, 17:10 »
the cars done 85k
. ill try that method of letting the clutch go.
richy_b
Re:putting in gear
25 January 2004, 22:08 »
does the clutch feel heavy all the time, if so it could be your cable on the way out?
this would explain 1st and reverse being hard
The garage
putting in gear
