Author Topic: Eek, got a leak. (bloody flood,more like!)  (Read 2458 times)
Offline veeeight
  • Assumption is the mother of all F**k Ups!
« on: 18 January 2007, 01:18 »
After recent heavy rains have developed a pond in my front passenger footwell. Evidence of water coming down  panel immediately in front of passenger door from somewhere at corner of dashboard area. Its a three door by the way. Car previously dryzabone.  :undecided: Danny.
2006/e95b_12.jpg[/img]
Offline veeeight
Re: Eek, got a leak. (bloody flood,more like!)
« Reply #1 on: 18 January 2007, 01:24 »
Have cleaned and greased up blower intake grill, and checked front scuttle water exit holes to no avail. ? Sunroof, screen rubber. Its def water and not antifreeze mix.  :undecided: Danny.
Offline Agreeable Slick
  • Unit
« Reply #2 on: 18 January 2007, 01:35 »
I presume when you say you have checked the drain holes you did the ones by the A pillar where that large chunk of rubber runs down to the wing? If not, check that, clean it out, and you should have no more problems.
Offline veeeight
« Reply #3 on: 18 January 2007, 02:10 »
Slick, when you talk of A pillar, do you mean the pillar that the door hangs on??
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #4 on: 18 January 2007, 10:15 »
thats the one mate, thats on the 45deg angle or whatever you want tio clal it by number, if you got the sunroof theres a hole in the front corners, the drain holes, which you can stik an airline down through th top of and blow the sh!t out, or even stick a wire coat hanger through ive been told
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline veeeight
« Reply #5 on: 19 January 2007, 23:54 »
Cheers mate, will check that once it dries up. (June probably!)
Offline Ben Lessani
« Reply #6 on: 20 January 2007, 22:53 »
door membranes, sunroof, scuttle tray, window seals...thats pretty much it.
my bet is door membrane
« Reply #7 on: 22 January 2007, 09:31 »
could also be the windscreen seal, thats where mine is leaking atm :(
Offline veeeight
« Reply #8 on: 28 January 2007, 21:59 »
Thanks for the replies to my problem. I'm going to work through the options. Can't see it being the door membranes as the leak is in front of the door. May be the window rubber and if it is may just change the screen at same time as some pleb has had a go at the windscreen with a bb gun prior to my buying the car. Sunroof drain tubes working. Grease that i smeared around the blower leaf guard may not be keeping water out, so may use silicon sealant there. Drain holes at ends of scuttle are clear also. Danny.
Offline veeeight
« Reply #9 on: 28 January 2007, 22:04 »
 Just had a thought, the car has been modded with a single wiper. Could it be one of the rubber bungs that are fitted to the old wiper arm holes is letting in water?? Danny.
