Author Topic: Eek, got a leak. (bloody flood,more like!)  (Read 2459 times)
Re: Eek, got a leak. (bloody flood,more like!)
« Reply #10 on: 28 January 2007, 23:36 »
perhaps, but it would still drain into the scuttle area, so would be coming in thru a cgrommet or fresh air intake if it was :)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #11 on: 29 January 2007, 00:49 »
im wary of picking up one of these mahle pollen filters as i dotn want to get rid of the leaf guard.. due tot he fact water will start pisisng through  :sad:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline systemseiko
« Reply #12 on: 29 January 2007, 07:26 »
Have the same problem with my 16V,  searched through the forum and done the following.
1.  Replaced both missing door membranes, with good quality builders plastic and duck tape, my electric window motor both shagged due to these been missing.
2.  Removed blower motor and found water incoming to foot well,  removed balck leaf guard and resealed with silcone.
3. Unblocked drain channels on "A" pillars with wire coat hanger,  blew out with air line and tested by fitting a 3/8 adapter from my garden hose to ensure water was free flowing.
4. Cleaned below scuttle tray,  found leak coming from incorrect fitment of grommet for clutch cable,  refitted  grommet and used silicone on all bulk head grommets.
5. Unblocked scuttle drain on NSF with coat hanger and tested with garden hose.
6.  Ordered new scuttle panel as my old one is cracked.
7. Hoovered passenger side footwell with local car wash hoover and hopefully leaks are now repaired :lipsrsealed: :lipsrsealed: :lipsrsealed:
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
