Author Topic: ECU Relay changing  (Read 1029 times)
Offline Ogmog
ECU Relay changing
« on: 17 January 2007, 21:56 »
Ive just read the common problems thing for the MK3 and think my car is having a problem with the ECU relay number 42. Where can I get this from? and a part number if possible.
Thanks
Offline Bazzer
Re: ECU Relay changing
« Reply #1 on: 18 January 2007, 08:05 »
That'll be a main dealer part bud. Don't have the part number on me but take the car in and they'll exchange about £12 for one.
Bazzer
Offline Len
« Reply #2 on: 18 January 2007, 09:45 »
On mine the ECU relay is No. 30 Sometimes I've seen it called E30
Best thing to do is go to your local VAG dealer, tell them your chassis number and they will give you the correct part for your car! Then you just replace the corresponding relay.
At 10 or 12 quid its hardly gonna break the bank.
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 18 January 2007, 14:21 »
i think the number you have is incorrect...check this list
Offline Ogmog
« Reply #4 on: 18 January 2007, 19:40 »
Ah right, i did read a few posts about relay 30 its just in the common problem thing from performance vw i said it had a big 42 on it. So i pressumed it was relay number 42  :embarassed:. Well cheers for the replies.
