Author Topic: MK2 16v clutch popped  (Read 1840 times)
Offline jimmy1182
« on: 16 January 2007, 13:24 »
Hey all,
I have a 1988 MK2 16v, i got in it the other day, started it fine and when i put my fut on the clutch there was a popping/snapping sound and the pedal went to the floor.  :cry:
 I thought it was the clutch cable but after inspecting it, it was all fine.
The nice man from the RAC who towed me home said there was a link between the lever arm and the clutch which has gone and i need a whole new clutch?
From what you've read does anyone know what is wrong and which bits i need, and in fact whether i need a whole new clutch?
Any help would be great.
Offline AudiA8Quattro
Re: MK2 16v clutch popped
« Reply #1 on: 16 January 2007, 18:23 »
The pushrod in the gearbox may have gone through the packing plate on the pressure plate.
Time to renew the whole clutch if that is the case.
« Reply #2 on: 17 January 2007, 09:50 »
Before you do anything else, remove the green end cap and check the clutch actuation finger, it may be cracked.  Jack it up a little on the passenger side, otherwise you'll loose a bit of box oil.  Have a new green end cap & release bearing ready, cheap from GSF.  If the finger looks ok, its a box off job as the release plate thing has prob gone as mister audi100 says.
In this case dont bother fitting the new cap & bearing, just put the old one in for now, becasue it makes it alot easer to replace the pushrod bush & seal if you tap it out from behind, I pushed summat long & thin into the pushrod hole, small enough to fit down the hole, but large enough to hit the pushrod bush.  Then I slid the pushrod down after it and gently tapped the bush out :)
Don't forget to replace the input shaft seal as well.
If all that sounds like a foreign language, have a read through of this:
http://www.brokevw.com
Explains everything in English & lots of pictures  :grin:
