Golf mk3
hardmonkeys
Rear wheel bearings on a vr6..
Topic: Rear wheel bearings on a vr6.. (Read 2597 times)
bulk66
Im broke an it aint a joke!!!!
14 January 2007, 02:38 »
Hi all are the rear wheel bearings on golf vr6 easy to do or not. I want to do them my self but if they are going to be a pain in the arse i wont bother. Any pointers cheers.....
robster23
Now a VW Fox Owner.
Re: Rear wheel bearings on a vr6..
14 January 2007, 10:01 »
As far as I am aware your bearings will be the same as mine - on a gti. They are within the rear brake disc mounting. I am told the pain in the arse bit is getting them out. I'll be handing mine to a trust mechanic to get them done but I don't think it is 'technically' very difficult.
hth
It's urban right? That means it must be tougher, obviously.... ;-)
SiGainey
14 January 2007, 10:05 »
You need a press. Best bet is to get the hub off yourself and take it to a friendly mech to push the fold one out / new one in for little £Â£Ã‚£
Dragon Green 97 Mk3 VR6
bulk66
14 January 2007, 10:20 »
I sourced 2 bearing kits off ebay for £2.99 each
so was going to do really cheap buy i might take it to a mech, its to cold.....
AudiA8Quattro
Forum addict
14 January 2007, 10:24 »
You don't need a press to fit rear bearing shells, they can be drifted in.
SiGainey
14 January 2007, 10:28 »
True, but it's very easy to get wrong. For the sake of a tenner or whatever, it's not worth it imho
AudiA8Quattro
Forum addict
Reply #6 on:
14 January 2007, 10:30 »
Its quite difficult to get wrong actually, well compared to pressing in a front bearing, which is easy to f**k up
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Reply #7 on:
14 January 2007, 13:24 »
I heard something about needing to change the abs ring's when swapping bearing's..is that right??? and i was also informed if the car need's rear disc's shortly it is worth swapping these while doing the bearing's as it will save changing twice..
AudiA8Quattro
Forum addict
Reply #8 on:
14 January 2007, 13:28 »
The ABS ring is pressed onto the rear disc(as far as i can remember),so to swap the bearings you don't need to change them.
However it is probably easier in the long term to replace the discs/bearings/ABS rings at the same time.
bulk66
Reply #9 on:
14 January 2007, 17:04 »
Cheers.....
Golf mk3
hardmonkeys
