Author Topic: lowering a mk4  (Read 1714 times)
Offline Starry
  • http://planetweed.co.uk
lowering a mk4
« on: 20 January 2004, 17:35 »
i have fitted a set of springs but the back is still a little high. Is there any way of brining the rear down a bit more without fitting coilovers???Cheers Starry 8)
1.8T 200bhp/237lbft.r32 F/BUMPER/ MILLTEK TURBO BACK,WITH HI-FLOW CAT/REVO/BAILY DV30/FRONT MOUNT I/C
Blue MK2
Re:lowering a mk4
« Reply #1 on: 20 January 2004, 19:05 »
Do what most people do...get huge subs and heavy sub boxes. Should sort the back end out ;) :P
Offline Cupra Turbo
Re:lowering a mk4
« Reply #2 on: 20 January 2004, 22:48 »
Face it, the mk4 is a blimp! ... its SOOO high up.
what springs u got? I heard you need a 60mm drop for the mk3/4 to remove the sizable arch gaps.
try awesomeGTIstore cos im pretty sure they do them... 40mm MIGHT be ok... but unsure.
if u just wanna stiffen the rear end up, just fire sum V6 springs onto it cos im sure their stiffer.
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
Offline Starry
Re:lowering a mk4
« Reply #3 on: 21 January 2004, 16:49 »
im running 18's and droped it 35/40mm and its ok at the front but the rear is still to high. i like the subs idea i may try that one. :D
check  it out on the link at the bottom of the page to see what you think..
also black-gti how did you get your pic to come up like that i put my link in but no luck ???
« Last Edit: 21 January 2004, 16:52 by Starry »
