Author Topic: 2.0 8v questions (that i don't think have been asked before!)  (Read 1379 times)
Offline Mew
Got a couple of questions:
Is it possible to swap over the crank and water pump pulleys on a 2e bottom end to the mk2 variety so a mk2 alternator can be used? Will they all line up? (NO power steering btw)
Is the mk3 oil cooler swapped over for the mk2 one, as i noticed there are 2 electrical connectors on the mk2 but only 1 on the mk3.
I know the cam belt has to be mk3 but not sure about the tensioner. Is it mk2 or mk3?
Thanks
Re: 2.0 8v questions (that i don't think have been asked before!)
« Reply #1 on: 12 January 2007, 12:15 »
1. Yes, but I'd stick with the MK3 setup, its much better.
2. no need, just plug everything into the MK3 senders, it should have 3 holes for senders anyway, so remove the blanks and screw in any senders that are missing.
3. MK2 & MK3 tensioners are the same :)
http://www.vwspares.co.uk
