Author Topic: Replacing Power Steering pump - Knobby's Back in town ;)  (Read 3451 times)
Offline knobby
Hi Guys
Well i'm back in another Mk2 Golf, another 8v, you gotta love them!
Need to replace the power steering pump, I have a second hand one to replace my very noisey one with, any tips on changing one, and what power steering fluid do i use, i understand its not a standard fluid its a special one from VW, and i right?
Been told to jack the front of the car up to move wheels left to right to get rid of any trapped air...
Its good to be back!
Knobby!
Old VW's never die...they just go faster!
Offline bomp
Re: Replacing Power Steering pump - Knobby's Back in town ;)
« Reply #1 on: 31 December 2006, 19:35 »
Keep the link below in your favourites knobby. (It's great for reference)
http://www.iol.ie/~kilkennyhockey//BentleyManual/
This is the page you want for the brake fluid part no & how to drain & refill.
http://www.iol.ie/~kilkennyhockey//BentleyManual/SU01/ch7.3.1.html
But I would imagine that most good oil/lubricant manufacturer of brake fluid with the same viscosity
will be as good. I think Oilman (Member name?) has put a comprehensive write up somewhere here, of
oils and their meaning, and has a list of the most highly recommended.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Neaty
« Reply #2 on: 01 January 2007, 13:07 »
I just used halfords power steering fluid, does the job just fine, never knew there was supposed to be a special type to use
« Reply #3 on: 02 January 2007, 20:11 »
For a MK2 system the correct fluid is Dexron II ATF fluid, aka Automatic Gearbox oil :)
Offline knobby
« Reply #4 on: 02 January 2007, 20:40 »
Been to a VW stealer this afternoon, picked up two bottle of their finest pas fluid. I was told i should empty the system and refil with new fluid. Would anyone recommend i flush the system before putting new fluid in and if so what flush?
Knobby.
« Reply #5 on: 02 January 2007, 23:52 »
id put in 2 litres of cheap atf, run it for 5 mins & bleed then drain again, that should get the worst of the crud out.  Be aware that if the VW stuff isn't ATF it may leak past the PAS system seals, the newer PAS fluid is a bit thinner IIRC.  Also it may make the pump sound noisy!
Offline knobby
« Reply #6 on: 03 January 2007, 00:04 »
I was told by the VW man its the same stuff they use across the board, was he wrong then.. Cos i went down my local automotive place and he told me it was special VW stuff. I dont want a noisey pump, thats why i am changing it in the first place.
« Reply #7 on: 03 January 2007, 07:57 »
The guy who told me it was Dexron II was Golden off ClubGTI, who used to work for VAG :)
What does it say on the bottle?
Offline Neaty
« Reply #8 on: 03 January 2007, 21:28 »
yea the stuff i used is automatic transmission fluid and it has II on the bottle if you get me, like grade 2 or what ever it means. dont get no noisy pump with that  :wink:. its like a pinky red colour.
« Reply #9 on: 03 January 2007, 23:23 »
yeah the II means dexron II, not I or III. Or IV, or V or XXXXIIIVIIIVIVIIVIVI  :grin:
