Author Topic: Magnex 4 Branch....  (Read 2146 times)
Offline Dub-77
  • Dub again MK1 Golf Project
Magnex 4 Branch....
« on: 23 December 2006, 20:42 »
1:How hard is it to fit a 4branch manifold to a 16v mk2?
2:Will I need to remove the top part of the inlet manifold?
3:Should I apply the heat wrap/ tape to the tubes?
4:People recomend a solid eng mount can I not just weld the old 1 up so its solid?
5:Oh and what sort of time should #i allow to fit this and a comp S/S system?
Darren
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
Offline FBF
Re: Magnex 4 Branch....
« Reply #1 on: 24 December 2006, 13:20 »
i cant help other than to let you know that...  HEADERS ROCK BABY!!!!!
Offline Dub-77
« Reply #2 on: 24 December 2006, 13:59 »
FBF I dont think anyone can help me on this one, never mind i'll have to find out 4 me self I guess  :grin:
Do you have heat tape on your headers?
Darren
Offline FBF
« Reply #3 on: 26 December 2006, 20:37 »
nope but mine are on a massive 5.7ltr chevy lump with lots of room.  if it were my golf id have the heat tape everytime.  just looks proper.  try to find the black one that harley davidson use. that stuff looks the nuts
Offline Lewy
« Reply #4 on: 26 December 2006, 21:03 »
Darren
Darren,
1, It's a pain in the ass if the engine is still in, but still do able.
2, Yes as it makes it slightly easier.
3, Yes.
4, If the new manifold has a flexible joint, then no you don't need a solid mount. And I wouldn't go down the route of welding up the existing one as it'll fail pretty quickly, regardless of how good your torch skills are. If you haven't got a flexi joint then BBM and EIP do a solid mount, check out the 'g-werks' website and the 'eip' one, this should do it.
5, 2-3hrs depending on your mechanical skills and that you don't snap any studs off! :angry:
Hope this helps
Lewy
Offline Dub-77
« Reply #5 on: 26 December 2006, 21:51 »
Lewy cheers for that reply mate..... perfect  :cool:
Now where can i get some heat wrap from by thursday morning? Any ideas of stockist open over the christmas brake?
Darren
Offline mk2mark
« Reply #6 on: 26 December 2006, 23:23 »
Heat wrap can be dangerous stuff, it doesn't reduce the heat it just moves it further down the exhaust. Also if you trap any moisture or leave any gaps exposed you're letting yourself in for problems. I'm not saying it's a bad idea just make sure you know what you want.
Offline Dub-77
« Reply #7 on: 27 December 2006, 00:02 »
Oh ok there is someting else to consider then thanks for that mark.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #8 on: 27 December 2006, 00:06 »
Alright Darren mate, GSF is open I believe, not sure if you got one nearby you though..
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Dub-77
« Reply #9 on: 27 December 2006, 00:13 »
Hello there thats a good idea thanks for that Beavis...
Darren
