Author Topic: heater matrix  (Read 1968 times)
Offline ian86
heater matrix
« on: 20 December 2006, 19:19 »
yes winter has finaly come and my heater doesnt work :angry:. I was told by a mechanic when i had my cooling system repaired that my heater matrix was blocked.
I was just wondering if any1 else had experienced this and new what the best way to go about it was and what the easiest thing to do was?.
Thanks
Offline T_J_G
Re: heater matrix
« Reply #1 on: 20 December 2006, 19:55 »
I've got no heaters either, i feel for you.  :laugh:
I'm hoping mines the bypass valve or something simple. Hope it doesn't come down to a new heater matrix....
Tim
Offline ian86
Re: heater matrix
« Reply #2 on: 20 December 2006, 20:01 »
Do you know how easy it is to do the bypass valve. Do you need to dismantle the dash or is it under the bonnet???
Offline ed325i
Re: heater matrix
« Reply #3 on: 20 December 2006, 20:03 »
Are the pipes going to the matrix hot ?
It could be your heater valve.
Offline ian86
Re: heater matrix
« Reply #4 on: 20 December 2006, 20:06 »
I dont know i havnt checked, how can i tell if its the valve or not???
Offline Uruk Hai
Re: heater matrix
« Reply #5 on: 20 December 2006, 20:22 »
If your heater's that bad you could try taking the bypass valves out or you could have a go at flushing the matrix out when I've done mine in the past I have allways flushed it the opposit way to the flow of the water. Personaly I would take out the bypass valves and see what that does, try this
http://www.golfgtiforum.co.uk/index.php?topic=31666.0
Offline ian86
Re: heater matrix
« Reply #6 on: 20 December 2006, 20:42 »
I don't know if i would be comfortable with removing a valve that vw had put there to be honest.
Offline Uku
Re: heater matrix
« Reply #7 on: 20 December 2006, 22:58 »
well alot of us have done it with no ill effects , they were put in when the mk2 was first released after a matrix supposedly exploded on someone whilst driving , these valves dont do anything until the pressure reaches a certian amount and it then opens a bypass between the two valves , given the size of the bypass pipe it cant release that much pressure , also given that the matrix problems were far and few between , i put it down to the matrixes themselfs rather than the pressure , just think this , most cars dont have this and put out similar pressures as the mk2 golf , also ive not heard anyone who has done this mod say this has happened. the damage that can be caused by one of those valves failing is a damn sight worse than a possible matrix failure and leak , i wish id removed mine along time ago as im a history lesson in the blocked valve , mine got jammed due to a fragment of metal (from the metal coolant pipe which ive replaced) getting stuck in the plate that moves , this consiquently increased the system pressure as it couldnt circulate properly (the bypass valve only bypasses a small amount to reduce the pressure a little if working properly) which in turn blew my headgasket and wrecked the water pump :(.
the decision is yours ofc , just my personal experience to those who wonder why some of us do this mod.
Judderi
Re: heater matrix
« Reply #8 on: 21 December 2006, 12:14 »
Stay cold then see if we care.
Offline NewStu
Re: heater matrix
« Reply #9 on: 21 December 2006, 12:17 »
here here.
