Author Topic: Heater Bypass Valve... How to... with pics!!!  (Read 21661 times)
Offline AndytheGreek
« on: 23 December 2005, 00:40 »
i was fed up with poor heaters so i took the plunge in the modification.
it was quite easy really...
youll need two small lengths of 22mm copper tubing
(about 4in and 5in)
a screw driver
some water and anti-freeze
heres what you have to remove:
heres what you put in its place:
the finished look:
this modification WORKS A TREAT, the heaters are UNBEARABLY hot too!!
i'll keep ya posted if my heater matrix goes, as its the original one from 1990.
Merry Xmas  :santa:  :smiley:
1990 Mk2 Golf GTI 16v
Judderi
Re: Heater Bypass Valve... How to... with pics!!!
« Reply #1 on: 16 January 2006, 08:58 »
Dont forget to massage your hoses a little when bleeding the system.
VeeDubGTI16v
« Reply #2 on: 16 January 2006, 10:26 »
wouldnt it be a better idea to replace with a new bypass valve than cowboy it :huh:
Offline Jet
« Reply #3 on: 16 January 2006, 11:12 »
but be sure not to burn youself ahem ,,..... :laugh:
Jet
On reflection ..A Golf is better!...
Judderi
« Reply #4 on: 16 January 2006, 11:56 »
Yeah if you could get new ones. They dont make them anymore mate. You can get 2nd hand ones but they will probably be just as busted as your own ones.
Offline Organisys
  • Old and Slow...
« Reply #5 on: 16 January 2006, 12:49 »
Yep, they are all prone to failing.
VeeDubGTI16v
« Reply #6 on: 16 January 2006, 13:24 »
i bought one from vw last week dude :grin: gonna fit it this weekend, it was just over £30
Judderi
« Reply #7 on: 16 January 2006, 16:31 »
Well your very lucky to find a dealership that still has some in stock.
Offline Chugadub
« Reply #8 on: 16 January 2006, 16:36 »
yeah i had to bin mine at weekend, tried bristol vw but they rekon they stopped selling them years ago.
an heater still dosnt work now.  :sad:
Cant afford a sig.....
Offline Mr Blue
« Reply #9 on: 16 January 2006, 17:19 »
Ive just done this to a valver.
New valves didnt even help! Heaters are warm now and the colant system is running as it should :smiley:
