Golf mk2
sagging drivers door on a mk2 how to sort it?
Topic: sagging drivers door on a mk2 how to sort it? (Read 9236 times)
Ciaran
GTI forum regular
18 January 2004, 13:52 »
just bought the car and the doors needs a bit of a bang to close it because its sits a bit low.
so how do i sort it and is it much work?
Blue MK2
Guest
Re:sagging drivers door on a mk2 how to sort it?
18 January 2004, 13:59 »
My passenger door did feel like it sat low but i adjusted the door lock mechanism and it shuts perfect now
Ciaran
GTI forum regular
18 January 2004, 14:10 »
this does sit low though maybe an inch or two is it just a matter of replacing the door pins?
Blue MK2
Guest
18 January 2004, 14:25 »
not sure mate. my dad used to fix these problems by putting a car jack under the door
Ciaran
GTI forum regular
18 January 2004, 14:29 »
well i thought of that already it just lifted the car then when lowered its still the same must be that trusty vdub build quality again! id rather sort it properly so it doesn't happen again.
jadegreen gti
18 January 2004, 14:44 »
my drivers door droped on my old golf i replaced the door pins'moved the door lock and mechanism+ abit of greace and was perfect untill some1 broke into my car with a crow bar and bent the whole door back (wan!ers
Davs mk2 16v
Reply #6 on:
18 January 2004, 15:09 »
shay is ur mota Jade green??
me thinks it looks fappin' awesome!!!!
jadegreen gti
Reply #7 on:
18 January 2004, 16:04 »
sweet motor mate
!!!!!!!! yes mate mines jade green alot of people have told me it rare
Gambit
Forum addict
Reply #8 on:
19 January 2004, 09:36 »
to fix the door all you do is get a wheel stud and jam it in the bottom door hinge and gently close the hinge, this will correct the sag in the door
dont close it too hard or you'll over correct it, just do it slowly bit by bit
if you do over correct it then just put the wheel stud in the top hinge and do the same.
i detailed this for the mk1 boys, its the same for mk2's
http://www.golfgtiforum.co.uk/index.php?board=6;action=display;threadid=4041
Last Edit: 19 January 2004, 09:37 by Gambit
Ciaran
GTI forum regular
Reply #9 on:
19 January 2004, 09:59 »
cheers mate il give that a go very helpful! ; )
Golf mk2
