Author Topic: VR6 Tensioner  (Read 1652 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
VR6 Tensioner
« on: 12 December 2006, 18:47 »
how much are these mine is making a noise
and are they D.I.Y job or garage job
Offline AudiA8Quattro
Re: VR6 Tensioner
« Reply #1 on: 12 December 2006, 18:51 »
Which one? the top one?
Offline VR6_ROB
Re: VR6 Tensioner
« Reply #2 on: 12 December 2006, 18:59 »
yeah the top one near the air box
Re: VR6 Tensioner
« Reply #3 on: 12 December 2006, 19:01 »
There isn't one near the airbox???
The upper tensioner is a banjo bolt, it is fitted to the rear of the right hand cylinder head. I would remove the cover and check the upper guide rail as well, as these are known to fail.
Offline VR6_ROB
Re: VR6 Tensioner
« Reply #4 on: 12 December 2006, 19:06 »
this tensioner is where noise is coming from
Re: VR6 Tensioner
« Reply #5 on: 12 December 2006, 19:12 »
Oh right i got you now. You mean the drivebelt tensioner, not the cam chain tensioners.
Yes its an easy diy job, you will need to wind a threaded bolt into the top of tensioner body(not to far) to release the tension on the belt, then unbolt the 3 bolts holding the tensioner to the cylinder head.
Do not tighten the 3 bolts up too much when refitting, as they strip easily!!
Offline VR6_ROB
Re: VR6 Tensioner
« Reply #6 on: 12 December 2006, 19:15 »
sounds pretty straight forward cheers bud are they expensive one i got on cost 4quid proberly why its buggered
Re: VR6 Tensioner
« Reply #7 on: 12 December 2006, 19:17 »
I think it cost me around 70 quid when i replaced it when i had the vr, but that was from vw, not sure if GSF or EURO do it.
Offline VR6_ROB
Re: VR6 Tensioner
« Reply #8 on: 13 December 2006, 13:05 »
64quid i got it for
i am gettin told to replace belt aswell but have you seen how close the pulleys are to the chassis leg
might just put tensioner on for now see if it sorts it out
Offline VR6_ROB
Re: VR6 Tensioner
« Reply #9 on: 14 December 2006, 18:14 »
dont know what i was worrying about took me 10 minutes if that
easy to change did belt aswell
