Author Topic: Tweeters  (Read 1772 times)
Offline MikeyB82
Tweeters
« on: 06 December 2006, 16:22 »
Need some advice the on MKIII's tweeters on the dash.
The original ones have four wires being plugged into the tweeter via two block-plugs.
I tried to fit some new 8cm speakers, which have only two terminals.
What is the best way of fitting these?
I tried using choc-blocs to take the two wires then twist them into one wire, but this (isnt good practice) only worked on one of the speakers, the other didnt work at all.
Doing this seemed to take the sound from the door speakers away.
Any ideas?
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: Tweeters
« Reply #1 on: 06 December 2006, 16:45 »
I'm not familiar with Mk3 set up, but from your description of what's there/what's happening it sounds to me like the tweeters have filters in them (which is a little odd, because these sorts of filters/xovers are usually fixed to the driver basket);
Anyhow, the (full-range) signal comes into the tweeter from the headunit and is seperated - the high end of the signal is played through the tweeter and the balance of the signal is spat back out (through the other pair of cables) down to your driver unit.
If you're fitting a new component set, you need to identify which of the two pairs is carrying the signal and connect that to your new crossover - this will then split the signal between your new tweets and new drivers*. If you're replacing the standard fit components with a pair of coaxials, again -  identify the incoming signal wire and take this directly to the new coax's.
If you're looking to run a new pair of coax's as well as the standard fit tweeters then you;re going to strugglre to do so without impeding the head unit (plus it will sound pretty pap as it will be massively over-trebbled).
If you can let me know exactly what you're trying to do/replace I might be able to help a little more/be a little more specific.
*To locate which of the two pairs of wires is the 'signal' pair, disconnet both sets from the speaker and test each pair of terminals with a multimeter, whilst music is playing (use it set to a very small voltage increment, it won't pick it up if you're using a 200v setting). The pair with the reading on the multimeter will be the pair connected to the headunit. You can also use this technique to determine which of the two terminals is positive and which is negative.
The greatest leveller of them all - the Carousel
Offline MikeyB82
Re: Tweeters
« Reply #2 on: 06 December 2006, 16:54 »
I have just found a pair of Pioneer Full range 8cm speakers which look a bit more manageable.
They have  a pair of coax soldered onto terminals, but also have a pair of unused terminals too.
As these speakers have four terminals, Im thinking these will work a bit better, I can keep each coax separated.
The plan is to take the four connections from the headunit, and using choc-blocs, connect each pair of wires seperatly to the terminals on the speaker.
(Trying to paint a picture of what im doing, but its difficult to describe!)
I think this method would work, but if have any more advice, keep it coming!
