Author Topic: mk2 gti help required please  (Read 1451 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« on: 03 December 2006, 11:57 »
hey all
my  mk2 gti (pb) has been running spot on since i have had it
but yesterday i got in it after i finished work
and fired her up but it just cut out straight away,
this continued 3 or 4 more times before i could floor it so i could rev it abit
then this morning i fired her up pulled off the drive and it cut out again
did the same thing 3 or 4 times struggled to rev it
started driving and it seemed to die in 5th put it into 3rd and it drove ok again
I have changed the dizzy cap and rotor arm but problem is still there
also in the wet it misfires now and again until its warmed up
dont know if thats anything related to it
cheers
rob
Offline kniterider
  • had most, sold most and often buy more!
Re: mk2 gti help required please
« Reply #1 on: 03 December 2006, 13:35 »
rob is this the vr6 lump thats playing up?? sounds common if it is...
Offline VR6_ROB
« Reply #2 on: 03 December 2006, 13:58 »
no its my gti lump in my 4 door
vr6 is problem free at the mo
but it aint on the road until next thursday,
dont want my gti to die on me
could it be plugs or leads?
i changed them in march time
Offline VR6_ROB
« Reply #3 on: 03 December 2006, 19:17 »
plugs and leads look fine
just been out in it and it did it again to me
anything else it could be
Offline xxdansigxx
« Reply #4 on: 08 December 2006, 14:16 »
try rotor arm or dizzy cap, maybe fuel filter have you checked that the leads are not grounding on the head happens sometimes just need to pull the rubber over anyway that's what i would check..
how does it cut out ie does it chug chug then stop or does it just idle low then cut out??
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #5 on: 08 December 2006, 14:23 »
Faulty Hall sender or Air Mass Sensor maybe ?! Vacuum Leak ?!
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline VR6_ROB
« Reply #6 on: 08 December 2006, 16:34 »
i cleaned the idle control valve out
and replaced the breather pipe that goes from the round piece o top of the rocker
as it was split
drives without spluttering but it wont hardly tick over now wants to cut out
and my knock sensor is broken so that could cause it to be ticking its arse off
just bought 20 50 oil see if i can quieten it down
Offline Mr Blue
« Reply #7 on: 08 December 2006, 16:39 »
get a nock sensor you shoddy git
