Author Topic: how to remove interior panel bit...  (Read 5404 times)
Blue MK2
« on: 15 January 2004, 11:56 »
Can someone tell me how to remove the rear plastic panel next to the rear window.
It rattles like a betch >:(
thanx in advance,
Blue MK2
Offline Dizzie
  • Make friends with your fast
Re:how to remove interior panel bit...
« Reply #1 on: 15 January 2004, 13:37 »
 ??? eh
Blue MK2
« Reply #2 on: 15 January 2004, 16:08 »
the black plastic bit between the rear heated glass and the rear side window. It squeeks and ratles like mad
Offline Dizzie
« Reply #3 on: 16 January 2004, 09:48 »
The C pillar then?
mine's started to squeek too  >:(
I'll have to look and let you know.
Veedubgt18v
« Reply #4 on: 16 January 2004, 18:27 »
grab it and tug hard?  :o  ;)  :P
Offline Dizzie
« Reply #5 on: 16 January 2004, 18:34 »
I had a look today...
obviously there the screw at the top. you have to remove the bit of shelf too. there's several 10mm nuts and it should pull free. the shelf holds the lower part of the panel down. I didn't actually take mine apart, but that's what I'm guessing is involved to remove it. I might remove mine and put some more dynamat behind them seeing as I have another roll spare.
Blue MK2
« Reply #6 on: 17 January 2004, 01:04 »
nice one. Mine sounds like there is a rat in the back. :-\
Ill give it a go 2moro
