Author Topic: AMP SUB RUN OFF ORIGINAL MK4 1.8T HEAD UNIT..( IS IT POSSIBLE)  (Read 2341 times)
Offline golfturbo
THE QUESTION IS UP THERE, CAN YOU RUN AN AMP AND SUBS OFF OF THE ORIGINAL HEAD UNIT AS ITS PRETTY GOOD AND I WANT TO KEEP THE CD CHANGER
Offline kniterider
  • had most, sold most and often buy more!
Re: AMP SUB RUN OFF ORIGINAL MK4 1.8T HEAD UNIT..( IS IT POSSIBLE)
« Reply #1 on: 29 November 2006, 19:53 »
yup!!
the gamma head unit has an extra socket in the back for line out and remote power (amp switch on wire etc), all you need is the correct adaptor to take your from the gamma (made by blaupunkt??) to normal line out and remote wire, but its is there so dont panic, if i can find a link ill post it here for the plug if not go onto ukmk4's site and ask on there someone will help no probs!!
Gaz
Offline golfturbo
« Reply #2 on: 29 November 2006, 20:03 »
CHEERS MATE, HAVE HAD DIFFERENT PEOPLE TELLING ME YOU CAN AND CANT BUT NO ONE ACTUALY TELLING ME WHY OR HOW..
Offline kniterider
Offline golfturbo
« Reply #4 on: 29 November 2006, 20:34 »
cheers for that, so do i just run my normal amp leads directly into them which inturn plugs into the standard stereo.
Offline kniterider
« Reply #5 on: 29 November 2006, 20:44 »
yup... just feed them into the two libe out rca plugs and plug that into the rear of the stereo, depending on what boot changer lead you have you may need to feed your exisitng rca's (line in) fromt the boot changer into the rca line in's on this plug as it uses sort of half a socket of your line in... sounds weird but get the lead, pull your stereo out and youll see what i mean!!
 :cool:
Offline Bluefox
  • ...back again!
« Reply #6 on: 30 November 2006, 07:59 »
We can get genuine Blaupunkt versions of these at Halfords for about £13, if that helps anyone :)
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
