Golf mk4
Wazzzer
Dashboard lights
Topic: Dashboard lights (Read 1968 times)
carl brian
Dashboard lights
28 November 2006, 17:55 »
On the golf i just bought, in the dark, the heater and vent knobs dont light up, is this normal?cant see if im turning the heat up or altering the speed of them etc
Jayy
Here all the time
Re: Dashboard lights
28 November 2006, 19:37 »
i got the same problem!!! they do light up cause my mates do!, but i aint got the slighest clue y they dont, hope some1 can help us lol
Mantamad
GTI forum regular
28 November 2006, 19:50 »
Golf vents dont light up but Bora ones do, many people do the conversion to Bora vents.
Black 2002 GT TDi 130
Stu-1.8T
Here all the time
Quit your Jibba Jabba
28 November 2006, 21:04 »
I'm pretty sure they are talking about the actual heater and fan speed dial lights that dont work. Not the vent lights (which are different on Bora's)
I would imagine you must be able to get behind the centre console and check the bulbs somehow?
fo0q
Just got here
28 November 2006, 21:47 »
its a simple job to fix.
put the heater speed to nukber 2 and pull the knob out with a pair of pliers. (use a rag or somethin wrapped around them so they dont damage the plastic).
There is a small bulb in there that needs changing. a set of pointy nose pliers should get it out.
theres only one bulb for the 3 knobs.
il try and find the part number but if you go to a dealers they should be able to get it for you, only cost about 50p
carl brian
29 November 2006, 14:17 »
that would be cool, cheers!
Jayy
Here all the time
Reply #6 on:
29 November 2006, 21:23 »
thank you
Jayy
Here all the time
Reply #7 on:
30 November 2006, 20:36 »
the bulbs a bit tricky to get out, the way i done it was too break the other bulb with tweezers and then put it out from the wire/fuse inside the bulb...and then solt it in, now works fine!!
thanks ppl
Golf mk4
Wazzzer
Dashboard lights
