Author Topic: tdi 100 cambelt due  (Read 4591 times)
Offline nadlad
  • Building Surveyor MRICS
tdi 100 cambelt due
« on: 21 November 2006, 14:43 »
my 02 with 46k is due a cambelt what do i need to do aswell as that should i change the water pump, and shud i buy the parts from vdub
is there a cambelt kit, been told to do it after 4 years or 50 to 60 k mite aswell do it
thanks
<<<Big Build Thread>>>
Offline richandhazel
Re: tdi 100 cambelt due
« Reply #1 on: 21 November 2006, 15:05 »
I've just done mine, only mine is on its 3rd having covered over 150K now. I did change the water pump, it was only £20 and they do advise you to change it if the vehicle has covered 100K or more.
I bought the whole kit: timing belt, tensioner, 2 rollers and and idle pulley. GSF sold the kit for £100. My kit is expensive as it is the AHF engine, I suspect yours will be cheaper.
Offline nadlad
« Reply #2 on: 21 November 2006, 18:45 »
now then thnaks for the quick reply rang vdub they said 355 inc vat my local mechanic said he wud do it all for 200  inc parts.
so just to cjeck i need to ring gsf tell them my engine code which is ATD and then they will have a kit is the waterpump a universal one?
will everythign i need be in the kit? what about pullys and tensioners etc etc
also do u knwo if a 16" montreal 2 with 205/55/16 will fit in the boot of a golf mk4 just that i had a avus 2 alloys 15 inch in there before and someone said it mite not fit in the pit bit.
Offline Bluefox
  • ...back again!
« Reply #3 on: 21 November 2006, 23:50 »
I'd use a VW belt and tensioner, just for "safety's" sake. The water pump you can get away with a decent quality aftermarket like QH or similar.
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
Offline Ridg
  • TDI - Soot Happens!
« Reply #4 on: 22 November 2006, 17:31 »
i got mine done at a local garage for £200 inc labour (ARL engine)
Offline nadlad
« Reply #5 on: 23 November 2006, 08:18 »
well my local garage is going to change the cam belt tensioners etc and the waterpump and the steering belt  coz they do start to go aswellfor £120 ( i supply the [parts)
gsf have the ATD code kit for £59 plus vat
 and the belt is about a fiver and the pump is £25
just out of curisoity do the mk4 tdi onlyhave 2 belts steering and cambelt or is there a auxilliray belt aswell?
i think the AC runs off the steering belt too.
thanks off to work... england battered in the 1st test harmison is a real worry.
« Reply #6 on: 23 November 2006, 09:04 »
2 belts. Cambelt and the auxillary belt (steering belt as you call it) that runs all the other components i.e PAS pump, alternator, air con.
For some reason the kit for the AHF engine is much more expensive than all the others.
Offline nadlad
« Reply #7 on: 23 November 2006, 20:26 »
cheers mate
