Author Topic: Derestricting the Airbox  (Read 1516 times)
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
« on: 13 November 2006, 13:48 »
Guys/Gals,
Am i right in assuming that a P reg 8v will have a Digifant engine?
I drilled out the airbox (wingside) last week and now thinking of popping in a Jetex Panel filter - they're quite cheap on fleabay.  Anybody using the Jetex Panel filter in their car, is it any good?
I read somewhere that on the Digi engines you need to remove a baffle from the airbox, does this also apply to the MK3?
How much should i pay for a panel filter, and do the Jetex ones need re-oiling like the K&N?
cheers
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Re: Derestricting the Airbox
« Reply #1 on: 13 November 2006, 15:55 »
if you look in the bottom half od the airbox, you may see a 'horn' type thing in there at the frontr, if so it should pop out with a bit of persuasion.  But since you've already driolled the airbox you probably wont see a great deal of improvement.  The only thing that happened when I took mine out is I got a nice induction roar when I floor it :cool:
As for panel filters, they are the way forward and I'd assume you have to clean & oil the jetex just like you would a K&N :)
Offline irmscher
« Reply #2 on: 13 November 2006, 17:38 »
thanks mate
Offline irmscher
« Reply #3 on: 19 November 2006, 19:16 »
as per my other post, there was a long plastic tube coming in from the air entry of the bottom half of the box...it wouldn't budge so ended up breaking it out...there is certainly a better noise coming from the box now and the Jetex Filter has improved the throttle response so good job all in all..
Offline vwagain
« Reply #4 on: 20 November 2006, 00:43 »
There are 4 lugs(2 at the top and 2 at the bottom)that need pushing in where the tube enters the airbox. The tube will then pull out with a little persuasion.
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline irmscher
« Reply #5 on: 20 November 2006, 17:28 »
thanks mate, i did see them but couldnt budge them...will it make much difference as i got quite a good break in it already right towards the entry point...?
