Author Topic: central locking pump for mk2  (Read 3813 times)
Offline crea8or
« on: 12 January 2004, 11:44 »
hi,
anyone out there ever bought a replacement pump please?
Any idea of price and where to find one?
Thanks!
Offline Fraiser
Re:central locking pump for mk2
« Reply #1 on: 12 January 2004, 11:51 »
i have one sitting around somewhere -
dont know how much they cost  - however if you are interested make us an offer.
Offline Gambit
« Reply #2 on: 12 January 2004, 11:56 »
test your existing one first, u can operate the gate on the pump by hand, if there is power reachins the pump then the doors will lock & unlock
if there is no power going to it then it'll do nothing
« Last Edit: 12 January 2004, 11:56 by Gambit »
Offline crea8or
« Reply #3 on: 12 January 2004, 11:57 »
thanks for the reply,
I found one on ebay that sold at the beginning of this month for ?10 plus postage.
is that any use to you?
Thanks
Offline crea8or
« Reply #4 on: 12 January 2004, 11:58 »
gambit,
thanks for the testing suggestion, I'll go and try that and see if it works.
Offline Fraiser
« Reply #5 on: 12 January 2004, 12:10 »
that will do,ill check to see if i still got it when io get home later today - then ill pm you.
Offline crea8or
« Reply #6 on: 12 January 2004, 12:40 »
thanks,
if you could check and then let me know I'll see your post when I get back into work tomorrow am.
thanks again.
ps. i did try to test it, but no sound of the motor. thanks for the idea though.
Offline Gambit
« Reply #7 on: 12 January 2004, 14:38 »
can you check to see if your getting power to the pump itself. it has continuous power even with the ignition off. multi meter, or else run a wire from the battery to the pump
the pumps dont fail but the wire giving power to it usally breaks somewhere between the drivers door and the boot
Blue MK2
« Reply #8 on: 12 January 2004, 15:15 »
Offline crea8or
« Reply #9 on: 13 January 2004, 10:56 »
Hello
Gambit - thanks for the very helpful advice to check the power wire.  I bought this car from my brother two months ago and just asked him, he said he got this checked, the power did work, so it appears I do need a new pump.
MK2 - thanks for the link to the pump on ebay, very grateful, I never spotted that.
