hi again just been looking into this over revving I'm getting in my golf gti 16v mk3 2l and so far i have read possible cause to be air mass meter, accelerator cable,o2 solenoid,blue temp sensor,throttle body microswitch,sticky throttle linkage or cable and the butterflies in the throttle body.
This morning i went out to check i cant even hear the hissing sound any more so I'm now sure i dint have a air leak. When i looked at the accelerator cable i saw it was quit loose is this normal ? if any one can i would appreciate it if you could have a look at yours and see if its loose and see what ring its sitting on when i moved mine up it was on ring 5. Or if anyone this these are not the likely problems please just say and give me some ideas thanks
