Author Topic: DSG and ROUNDABOUTS  (Read 4972 times)
Offline waddler
DSG and ROUNDABOUTS
« on: 05 November 2006, 08:53 »
Had another drive of the DSG GTI in an attempt to make up my mind.  The system really is great but I struggled with changing gear mid roundabout.  Thats because you have to take your right hand of the wheel where the upshift paddle is to turn.  Would like to know how u guys handle it.  I guess you just use the stick??
Offline wantmygti
Re: DSG and ROUNDABOUTS
« Reply #1 on: 05 November 2006, 11:44 »
I think technically speaking, you shouldn't be changing gears mid corner, but it did seem weird not having the paddles attached to the wheel itself. Didn't like the lack of engine braking either.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline lowdown
« Reply #2 on: 05 November 2006, 11:51 »
I found this too and consequently this was my main reason in choosing a manual box.  I suppose these are the situations when it is best to use the fully automatic setting.
The manual box is superb, and coupled with the best 4 pot in the business, only good things can happen! :smiley:
Offline Cass
« Reply #3 on: 05 November 2006, 14:56 »
Try an advanced driving course - don't ever change in mid-corner, you will unbalance the car. Always brake in a straight line and change gear before any hazard. Repeat this mantra:
I - Information
P - Position
S - Speed
G - Gear
A - Accelerate
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline waddler
« Reply #4 on: 05 November 2006, 15:01 »
You obviously haven't driven around any large roudabouts then.  Assuming its too early to change into 2nd before you turn the wheel byy 1/4 that means according to you you have to keep it in 1st.  Don't think so.  Also at less than 20 miles an hour i don't think unsettling the car is an issue.  Hardly on the limit are you!!
Phil mcavity
« Reply #5 on: 05 November 2006, 15:10 »
why on earth are u in tiptronic mode, use the auto mode thats what its for!!!    tiptronic and sport mode is for track use only, or ment to be! :wink:
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #6 on: 05 November 2006, 15:50 »
Agreed - Choose your gear pre bend / round about  :wink:
And pay for the paddle shift  :wink:
« Last Edit: 14 November 2006, 21:13 by The Doc »
Offline ReDBull
« Reply #7 on: 06 November 2006, 10:28 »
I no DSG is faster and a lot less of a pain in traffic but really don't no if I'd buy a car with it again. Having test drive a few different car's over the last few weeks I think I'm beginning to miss the manual. Doc any luck in finding a heads up display?
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline Shins
« Reply #8 on: 14 November 2006, 11:21 »
Sure DSG has a few niggles or 'features' that can get you down. Sadly my car is getting a new front end  :cry: and I have a replacement car while its in. I have a Vauxhall/Opel Astra auto which has to be driven to be believed! Its comical, like they got a 3 year old to copy the DSG system. In full auto mode there is a time delay between gear changes of about 1.5 seconds! In both the 'manual' and auto modes the car lurches between each gear change making you feel sick.
If you need a laugh go and test drive one, and you'd never complain about DSG again!
Phil mcavity
« Reply #9 on: 14 November 2006, 18:42 »
ive used sh!troens dsg version, called the "sensodrive", fitted in my once owned c2 vtr, used paddles behind wheel, same as gti , and like the previous thread, the dsg system is the best by a country mile imo.horrid lurches, cant make its mind up what gear to select in slow moving traffic. i canot say a bad word against my dsg system, no going back to manual gearbox for me anymore!
