Author Topic: NEWBEE- just bought these 15inch wheels and need help.  (Read 2676 times)
Offline lazybluekarmen
BEFORE WE START I HAVE BEEN LOOKING FOR HOURS FOR AN ANSWER SO I CAME HERE...
These are the wheels i got
http://www.motor-world.co.uk/images/hires/8661.jpg?PHPSESSID=c55d3cb729e872143b2fdbff2b6a103e
15inch with yok tyres, they were on a corsa for 4 days so they are brand new.
(£195 i payed)
i also got a full set of locking nuts and some sprigot rings.
Check the charts i found below and see if you agree with this.
THE SPIGOT RINGS I GOT ARE 56.6MM(VAUXHALL), CAN I RUB THEM DOWN ABIT ON THE INSIDE TO MAKE THEM 57.1 (VW) SO THEY FIT?
 SAVING £20 AND TIME...
DO I NEED SPACERS WITH THESE WHEELS?? DON'T UNDERSTAND THE OFFSET THINGY...I WANT THEM TO LOOK WIDE...
I DON'T KNOW IF SHE HAD SPACERS OR WHAT THE OFFSET OF THE WHEELS ARE NOW??
I FOUND THESE ON THE NET
VAUXHALL
Model P.C.D.           Offset         C/Bore
Corsa 4 x 100      42...45              56.5
VOLKSWAGEN
Golf      4 x 100        32...38        57.0
from here  (http://www.carlsalter.com/wheel_fitments.html)
sprigot rings available on ebay are these
56.6mm Vauxhall / Daewoo
57.1mm VW / Skoda / Audi
ANY ADVICE WILL BE GREATFULLY ACCEPTED AND REPLYED TO.
CHEERS
LAZYBLUE :laugh:
Re: NEWBEE- just bought these 15inch wheels and need help.
« Reply #1 on: 28 October 2006, 18:26 »
It a f reg karmen clipper by the way..
Offline Stu.750
  • MMMMMMM Rust my favourite
« Reply #2 on: 28 October 2006, 18:30 »
no amount of rubbing could ever make 56mm into 57 , if it could id be huge by now ,
 anyways all ya could do is throw em on and work with a bit of trial and error
there should be a guid on offsets somewhere , its measure in mm i think from the centre of the wheel to the inner edge i cant remember , ill dig it out and write it up for you if youd like
« Last Edit: 28 October 2006, 18:34 by StuDubs »
« Reply #3 on: 28 October 2006, 18:50 »
1st thing, check if the wheels have spacers/spiggot rings in, I bet they will!  If so you can just pop em out and buy some TSW VW fitment spacers, and away you go.  Plenty wheel shops should be able to supply you with a set, even halfords should be able to get hold of them since I beleive they stock TSW wheels!
« Reply #4 on: 28 October 2006, 18:57 »
cheers stu, it all helps and i might end up understanding things.
jonny, i got the vaux spigot rings with the wheels and i could get them on the golf with a bit rubbing. Do i need spacers? thats the question, i will go to halfords and ask but you know what its like when you get new gear,  I WANT TO KNOW NOW!!!!!     lol
cheers lads, what u think of the wheels? i'm not sure but i couldnt day no at that price...
Offline Stu.750
« Reply #5 on: 28 October 2006, 19:30 »
depends on the colour of car ,
 doh , im dim , yeah think theyd look pretty cool , maybe try n find some non TSW centre caps , if ya want rid i think theyd look pretty cool on my mars red mk1 gti
« Reply #6 on: 28 October 2006, 20:07 »
stu, the car is lazyblue in colour, tried loads of times to post pics but can't work it out.
Give me what i payed today and they are yours. £195 with lock nuts
Offline Stu.750
« Reply #7 on: 28 October 2006, 20:25 »
if i wernt on monthly pay mate n not gettin any till tuesday i would have em off ya
 you need to used  photobucket for pics
 try this link it xplains
http://www.golfgtiforum.co.uk/index.php?topic=2049.0
« Last Edit: 28 October 2006, 20:26 by StuDubs »
« Reply #8 on: 28 October 2006, 23:33 »
IIRC the vaux offset is slightly higher than VW, (higher offset means they sit further in the arch) but its not a massive amount. They should probably fit ok and not catch anything but you might want spacers so they fill the arches out a bit more.
Since the spiggot rings are probably plastic you could probably squeeze em on no bother.  Just be aware when you take the wheels off the spiggots might be proper stuck on there, and you may have to break em to get em off...
« Reply #9 on: 30 October 2006, 19:18 »
photo i think
 :laugh:
