Author Topic: Where to earth? Golf mk3 cabriolet  (Read 3298 times)
Offline capoach
« on: 26 October 2006, 12:56 »
Can somebody please tell me where is a good point to earth my amp in the boot of my mk3 golf cabriolet. I am currently having the problem of the sub fading in and out of power the car is in motion and stops, for example when the car is in motion it fades out and when i stop at lights it comes back on  :huh:. This has led me to the fact it may be the earth that needs moving. Any help would be good. Cheers Mike
Offline Bluefox
  • ...back again!
Re: Where to earth? Golf mk3 cabriolet
« Reply #1 on: 26 October 2006, 21:49 »
If I've ever had a problem with an earth, I just drilled a hole in a box section on the boot floor and put a self tapper in it with a washer.
Obviously remember to connect your earth cable to the screw, for obvious reasons.
And no, as you mention it, I haven't ever done that. At all. Ever. Nosiree.
:rolleyes:
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
Offline V_Arse6
« Reply #2 on: 27 October 2006, 10:18 »
I just used one of the headlight securing bolts.  Not looked in a cab boot, but I assume you'll have those!  :laugh:
Of course, it does probably mean you'll need a longer earth cable though, depending on your Amp's position...
'95 Mk3 VR6
FK Highsports, Crystal Clear Fogs/Indicators/Repeaters, Mk4 Style Headlights, PiperX induction, Bonnet lifters. (Need to update pic for new headlights)
Offline Bazza
« Reply #3 on: 30 October 2006, 14:52 »
Don't forget you need to make the earth point as close as possible to the amp. Make sure it's a good earth, remove the paint a good distance around the earth contact  point then cover it in hammerite so it won't rust. :smug:
WELCOME TO THE DARK SIDE
« Reply #4 on: 31 October 2006, 17:38 »
If you can find a large enough ring terminal, what about using one of the seatbelt clip mounting bolts?
