Author Topic: What are these connections? (with pics)  (Read 1514 times)
Offline golfmk2boy
« on: 22 October 2006, 16:08 »
Lads,
Can anyone identify and tell me where these need to go;
The vacuum pipe, fits to a plug behind this lead, i dont know where that vacuum pipe should go?
and...
Offline Mr Blue
Re: What are these connections? (with pics)
« Reply #1 on: 22 October 2006, 16:17 »
the bottom pic is the earth strap that goes from that earth plate to a metal sheild around the dizzy cap
ignore it if ou dont have the metal sheild thing :smiley:
cant work out the vacum hose. Could be off the brake vacume hose. not sure
Edit: If you have a soft brake pedal with the engine running then block that vacume hose. I had a similar problem and almost crashed :shocked:
« Last Edit: 22 October 2006, 16:26 by Mr Blue »
Offline golfmk2boy
« Reply #2 on: 22 October 2006, 16:27 »
Thanks for that.
My brake pedal wont move at the moment so that sounds about right...
Veedubgt18v
« Reply #3 on: 22 October 2006, 16:27 »
no it isnt thats on a 16v i think. that goes from where it is attached in your pic to the mount for the coil on the bulkhead. its the coke can sized thing that the centre lead for your dizzy cap comes out of.
Offline Mr Blue
« Reply #4 on: 22 October 2006, 16:31 »
well it is on my 8v :laugh:
binned it. looked crap :tongue:
Veedubgt18v
« Reply #5 on: 22 October 2006, 16:35 »
it earths the cylinder head. as long as it is connected to the chassis somewhere it will be fine
Offline golfmk2boy
« Reply #6 on: 22 October 2006, 17:14 »
Would it cause the car not to start if it wasnt earthed?
I have just swapped my motor and it is not starting, I can only hear the fuel pump (i thinK)
Offline Uku
« Reply #7 on: 22 October 2006, 18:58 »
that strap comes straight from the battery negative terminal , car should still start without it though , the other hose is from the white clear hose to the bottom of that one way cream valve . its the vacuum sender for the MPG option on the back of the dashboard. i can tell it is as on your picture ya can quite clearly see the transparent hose hanging there to the right :p
« Last Edit: 22 October 2006, 19:00 by Uku »
Offline Uku
« Reply #8 on: 22 October 2006, 19:03 »
p.s your leads look nice and new but that coil (top right) looks like its been on there a few years and has seen its day lol , if ya get any igniton problems in the future keep an eye on that , coils break down after a while.
also keep an eye on that steel coolant pipe , looking rusty and they eventually rust through , replaced mine recently after i developed a leak on the elbow of it.
« Last Edit: 22 October 2006, 19:05 by Uku »
Offline Uku
« Reply #9 on: 22 October 2006, 19:09 »
ah also somin else , the brake issue is either air in the brake fluid system caused by either a recent change and they havent been bled properly or very old brake fluid that needs changing. check to see if the pedal goes 'stiff' after you turn the engine off and pump it several times. if it still goes to the floor after the engine is off and you do this the master cylinder is leaking and needs replacing which will also cause 'soft' brakes.
