Author Topic: short shift  (Read 832 times)
Offline rowlers
  • I'm back - MK7 GTI
short shift
« on: 20 October 2006, 21:05 »
which bit of the gear linkage is repalced by a short shift kit?
I've seen loads on ebay (various prices), but can't work out what they replace to shorted the shift!
If someone can provide a pic of the bit hat is replaced, I'm sure I'll be able to get ad adjustable one made.
cheers
Re: short shift
« Reply #1 on: 25 October 2006, 13:48 »
There are 2 ways of doing it, 1 way is to remove the part that is bolted to the gearbox, and shorten it and bend  to a right angle, the other is to extend the large lever on the bracket bolted to the steering rack :)
Offline rowlers
Re: short shift
« Reply #2 on: 25 October 2006, 17:20 »
now I' confused!
the ones you can buy on the bay, which bit do they replace?
cheers
Re: short shift
« Reply #3 on: 25 October 2006, 17:25 »
depends which type you get :grin:
Normally the ones you get on ebay either replace the lever on the rack mount bracket, or attach on the end:
http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml#ShortThrow
