Author Topic: 16v Performance uprgrade .  (Read 2340 times)
Offline t111bul
« on: 19 October 2006, 20:56 »
My track day car needs more go, What upgrades can i do that aren't going to cost the earth ?
Offline Gambit
Re: 16v Performance uprgrade .
« Reply #1 on: 20 October 2006, 09:51 »
WUR regulator mod. costs nothing & is detailed in Maintenance section
http://www.golfgtiforum.co.uk/index.php?topic=31611.0
my 1.8 16v was standard apart from WUR adjusted and big centre (square shape) silencer removed and it was running at 153bhp.
im in process of getting a head done for it also. then ignition is getting remapped using superchips ignition module. hoping to be touching 175bhp by the end of it all. keeping std KR cams also
« Last Edit: 20 October 2006, 12:34 by Gambit »
Offline rowlers
  • I'm back - MK7 GTI
« Reply #2 on: 20 October 2006, 18:16 »
sorry to pinch the thread!
Gambit has the WUR mod caused any starting issues? Have read somewhere that it can cause trouble?
Also whats your MPG like? I'm currently gettin around 30mpg, will it make much of a difference?
It sounds like a lot of bang for buck!!
cheers
Offline Gambit
« Reply #3 on: 20 October 2006, 19:52 »
i just run with the cold start valve disconnected and it starts, runs fine.
with it connected it floods itself in the morning
didnt notice any real difference in economy. i get around the 30 mark also
Offline rowlers
« Reply #4 on: 20 October 2006, 20:24 »
So the WUR is always connected (electrically), but you have disconneted the electrical connector to the cold start valve?
Did you get this done at stealth? Or did you just do it yourself of the guide??
deffo getting it done especially as I have a spare WUR!
cheers
Offline Gambit
« Reply #5 on: 20 October 2006, 20:32 »
yes WUR remains connected all the time & cold start (blue plug) is always disconnected
me and a mate done it. Stealth would involve a ferry trip over from N.Ireland!!
defo worth it if you have a spare WUR
Offline rowlers
« Reply #6 on: 20 October 2006, 21:01 »
off to the garage in the morning then see what my mechanic reckons!
Hopefully he will have the necessary gauges!
got to be worth a go for 15-20 stallions!
what do reckon I'll get with the flowed head and cams?
Offline Ryan
  • Scotland
« Reply #7 on: 22 October 2006, 11:20 »
replace you inlet cam with an exhaust cam. Just gives it that little bit more lower down apparently.
WANTED:: 16v crankshaft pulley and rear windescreen washer bottle
Offline D16vGti
« Reply #8 on: 23 October 2006, 17:00 »
Whats the part number for the WUR on the link in the maintenance section?
Don't question it.....just enjoy it!
Offline D16vGti
« Reply #9 on: 23 October 2006, 17:02 »
Sorry didn't read it properly!  :embarassed:
Where can I buy a WUR?
