Author Topic: AUDI QUATTRO......... HERE'S ONE TO GET YOUR BRAINS TICKING.  (Read 1164 times)
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
HI EVERYONE, SORRY I AIN'T BEEN ABOUT MUCH LATELY. HAD PROBS WITH MY LAPPY AND INSTEAD OF SORTING IT I HAVE BEEN SAVING OT FINISH OFF AN ENGINE I AM BUILDING.
I WILL EXPLAIN:-
ORIGINALLY I ACQUIRED A PB HEAD AND A 2E BLOCK. I HAVE PORTED AND POLISHED THE HEAD. ITS BEEN TESTED AND SKIMMED WITHIN AN INCH OR 1000TH/INCH OF IT LIFE. NEW TAPPETS, MODIFIED VALVE STEMS, FULL HEAD SET AND PIPER FAST ROAD CAM.
I NOW PLAN TO START THE BLOCK REBUILD BUT JUST HAD A SPANNER THROWN IN THE WORKS.................
I HAVE BEEN OFFERED A GOOD CHEEP AUDI 2.3 20V NON-TURBO'D 170BHP QUATTRO (G). I WAS THINKING I COULD USE THIS AS A DONOR CAR AND PUT THE ENGINE AND RUNNING GEAR INTO MY GOLF. I KNOW ITS A MOUNTAIN OF WORK COMPARED TO THE 2.0L COVERSION I HAD PLANNED SO MY QUESTIONS ARE THESE:-
IS IT WORTH DOING THE AUDI CONVERSION?
SHOULD I LEAVE IT ALONE AND STAY ON COURSE FOR THE 2.0L CONVERSION?
SHOULD I BUY IT FOR THE INTERIOR, FRONT BREAK SET-UP 273MM DISC'S AND 2 POT CALIPERS, ETC?
WHAT WOULD YOU GUYS DO????????????????
THANK FOR YOUR FEEDBACK.
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
Re: AUDI QUATTRO......... HERE'S ONE TO GET YOUR BRAINS TICKING.
« Reply #1 on: 19 October 2006, 10:21 »
Are you thinking of using the 4 wheel drive system aswell?
Offline kniterider
  • had most, sold most and often buy more!
« Reply #2 on: 19 October 2006, 10:27 »
nothing is im possible if you have the ability to do it, the tme , money and space, if the body aint bad on the audi and its taxed and tested id run around in it whilst you get the golf done.... i think from a engine conversion, to doing a full on drive train conversion (plus other mods as drive train maybe longer/wider than the golf floor pan..) is too much work, i like them audi's any ways if it aint that bad would be a shame to rip it to bits!!
 :smiley:
Offline turbodub
« Reply #3 on: 19 October 2006, 11:16 »
You will probably see the same or even slightly more power at  the wheels with the 2e/pb combo, particularly if you have ported the head and fitted a more aggressive cam. The drivetrain losses of the quattro will basically nullify the extra horsepower of the 5 cyl engine.
Then of course there is the extra weight you would be adding to the car. Stick with the 2e :)
Offline jase555
« Reply #4 on: 19 October 2006, 13:05 »
OK SO IF I STAY WITH THE 2.0L BLOCK COULD I AND WHAT DO YOU THINK ABOUT FITTING THE QUATTRO SYSTEM TO THAT IF I SAY GOT MY HANDS ON A RALLEY BOX AND TRANSFER BOX?
I THINK I WILL PROBABLY KEEP THE AUDI AS IS THEN JUDGING FROM YOUR FEED BACK. MIGHT MAKE A NICE CAR FOR THE BRIDE. I WHICH CASE I WOULD SELL HER GOLF GTI 8V AND KEEP MINE.  :evil:
THANKS FELLAS.
Offline Jamo_GTI
« Reply #5 on: 19 October 2006, 16:18 »
I wouldn't do it, you need the S2 engine 2.2 turbo to do the job properly.
Grant at AET is it? has dont this in a MK1 golf it frequently pops up on my audi forum
What engine code is it? is it the 7A or NM?
Proud owner of a Golf MK2 8v and Audi RS2
Offline jase555
« Reply #6 on: 19 October 2006, 19:16 »
its the high compression 7a engine.
which audi forum?
regards
jase
