Author Topic: Starting her up for the firs time  (Read 874 times)
Offline golfmk2boy
« on: 18 October 2006, 14:47 »
Golfers,
I have finally fitted my downpipe, so everything is ready for my newer 8valve digifant engine to be started up.
Just before I do this I would like to know whether there is anything that I should do before I do so?
I will fill her up with oil tonight, then let it settle for 24 hours, then top her up again some more before starting.
Offline turbodub
Re: Starting her up for the firs time
« Reply #1 on: 18 October 2006, 15:01 »
Have you done a rebuild, or is it a used engine you have fitted?
If you've done a rebuild, remove and earth the coil lead to the distributor and turn the engine over on the starter until the oil pressure light on the dash extinguishes.
If it is a used engine then just fire it up straight away  :grin:
Offline Jonp
« Reply #2 on: 18 October 2006, 16:59 »
If it is a rebuild i'd also squirt a little oil down the spartk plug holes...
Good luck!
Offline golfmk2boy
« Reply #3 on: 18 October 2006, 20:09 »
It is a used engine.
