Author Topic: Blooming rear calipers.  (Read 1343 times)
Offline DanT
« on: 16 October 2006, 14:09 »
Hi all,
I have had a search around this fine fine forum on this subject and it seems I am not alone in pulling out me hair with these damn rear calipers. Car is a 95 8v gti by the way.
My situation is similar to others, hand brake not holding and the rear brakes not giving it their all. wheel off and pads out obvious signs of kak built up but more pressing is one of the sliders? rusted into the caliper carrier. Ah bum me thinks and opts for some oil on it and leave it whilst down some tea and mutter away about it to my wife. Then back out and gently try to wiggle the thing loose. I was careful to check the other and see that the slider is grooved so turning it out not an option.  more oil n tea (for me, well the tea was)
More gentle wiggle and ting the thing is in two pieces. The 15mm nut in my hand and the rest still in the carrier. Ah bum (for the second time) me thinks.
So off with the carrier, er yeah right corroded in after 11 years and 90k sat there holding it all together.  Banged in the 8mm allen key, on with the drive and nothing. You know the story lots of pulling, hammering and a big breaker bar and nothing happened.
That was Saturday and I have left the beast oiled up.... for the last couple of days.
Now I did toy with the idea of drilling the slider out but can you get replacements on the off change I pull that trick off? It seems like an A team style long shot but we might make it kind of treatment though. There isn't a lot of space to get in there and do it right is there.
So I am left thinking I might have to grind the blinking thing off. What you recon? Any other tips to move a stubborn mother like that?
Sorry am rambling away like Janet Street porter.
Dan T
95 MKIII gti 8v.
97 T4 syncro caravelle.
Offline chrutchy
Re: Blooming rear calipers.
« Reply #1 on: 16 October 2006, 18:56 »
when i done mine ive got a socket set made by IRWIN that
will go over a rounded nut and lock on to it so u wont have to round
off the allen key and u can use a half inch rachet on it
with extension bar
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=96028
this is what they are. there is ann add on to the set as well
so in all there is ten in the set
Offline AudiA8Quattro
« Reply #2 on: 17 October 2006, 22:35 »
I've got a set of them, and they are brilliant  :cool:
Offline vwagain
« Reply #3 on: 18 October 2006, 00:14 »
Me too, the best £20 i ever spent :cool:
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline nitro
  • sometimes it just has to be done.....
« Reply #4 on: 18 October 2006, 14:48 »
have you tried a bit of heat onto the calliper body, with a blow torch. dont go mental with it but a bit around the stuck part often works wonders :-)
Offline DanT
« Reply #5 on: 20 October 2006, 10:28 »
Hi all cheers for the replies, not done any more to this as been laid low with bloody food poisoning.
I did try some heat on it too, nice and gentle but still no joy. I think I will be making that £20 purchase to get to buggers out.
I shall let you know how I get on this weekend if I get enough strength back to have a go.
Dan T
95 MKIII gti 8v.
