Author Topic: God damn Electrical Diagrams  (Read 2367 times)
Offline Gambit
« on: 08 January 2004, 10:15 »
right this diagram says the ISV is controlled by fuse number 17, does this mean simply i need to check location number 17 in the fuse box??
http://homepage.ntlworld.com/kevin.yeoman/16v_isv_wiring_diagram.jpg
surely it cant be as simple as this? the fuse box cover says fuse 17 is for the turn signal??
Offline richandhazel
Re:God damn Electrical Diagrams
« Reply #1 on: 08 January 2004, 14:50 »
S17 should be fuse 17, but, I would be more inclined to believe your cover. Have you definately got the correct wiring diagram for your car?
Offline Gambit
« Reply #2 on: 08 January 2004, 15:36 »
yep its defo NOT it!!
took the fuse out, and low & behold it is the indicators
maybe that the diagram for the earlier electrics pre 89 models
« Last Edit: 08 January 2004, 15:46 by Gambit »
« Reply #3 on: 08 January 2004, 15:46 »
yep its defo it, i thought the turn signal was controlled by a relay though?
Yeah but so do the wipers, fuel pump etc., but they still need to go through a fuse to protect the circuits.
« Reply #4 on: 08 January 2004, 15:48 »
Fuse layouts do seem to change with the years so would be worth checking. Good luck.
