Author Topic: Gear Selector - 1st gear  (Read 1666 times)
Offline VWaxilMK1cab
  • 1992 mk1 cabrio gti
« on: 13 October 2006, 16:38 »
My 1st Gear is being a b!tch! sometimes it's ok, then other times it goes into 3rd and you have to go into 2nd and slam it back up to get into 1st. Not good.
Aparantly it's a VW thing, is there some adjustments which can be done?
Chris.
Offline alpesh
Re: Gear Selector - 1st gear
« Reply #1 on: 13 October 2006, 18:52 »
I had the same problem. Down to worn out gearlinkages and adjustment. GSF do a bush kit for about £5.
Offline alpesh
« Reply #2 on: 13 October 2006, 18:53 »
Thats gearlinkage bushes.
Offline richandhazel
« Reply #3 on: 15 October 2006, 00:05 »
Sounds like it needs adjusting. There is a good 'how to' guide out there somewhere. I'll see if I can find it for you.............
« Reply #4 on: 15 October 2006, 00:08 »
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #5 on: 17 October 2006, 18:46 »
Please note there are two kits from GSF both good value, one is just bushes the other has the lower part of the inside the car gear lever parts, but I found out this weekend that if you replace the lower part of your gear lever inside the car, that the spring in the GSF kit is too short and thus allows you to push down the gear level too much and doesn't allow you to slot into reverse properly, so be warned, everything else in the kit is correct. Sometimes buying from VW themselves will be cheaper than GSF, I managed to get a replacement spring from VW for 60p - bargain ;)
The link above is very useful.
Si
« Last Edit: 17 October 2006, 23:19 by Madone_si »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline Danny
« Reply #6 on: 17 October 2006, 21:45 »
I had the exact same problem. U need to buy a Shift Bushing kit. Check Ebay they always have it. Easy to install just need to get under the car. Should solve the issue right a way.
No DuB should die.
