Author Topic: Flashing temp light, pt 2  (Read 2111 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« on: 10 October 2006, 22:19 »
Ok so leaving it on on ignition, batt and oil light, usual ignition drill, but the the tmep light eventually coems in as well, cold engine, not running or even started..
Dodgy connection?
Dodgy sensor?
Only have black and red sensors on housing, and no sensor on expansion.
Oh and have a kink, but not a broken wire, on top my block, the 2 sensors there, oil and whatever.. possibly related?
And also the temperature gauge goes half and fan kicks in and everything stays hunky dory  :laugh:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Re: Flashing temp light, pt 2
« Reply #1 on: 11 October 2006, 10:05 »
thats normal, the light comes on to tell you its working
« Reply #2 on: 11 October 2006, 11:34 »
this is constant flash john, not just the 2 flashes, its constant and then continues after engine starts.. but then this morning from cold it seemed ok!
Quote
« Reply #3 on: 11 October 2006, 13:08 »
could be a sensor issue, though normally the gauge shoots to max or doesnt read at all.  You may have a faulty temp gauge!
« Reply #4 on: 11 October 2006, 18:34 »
I told you once already, no GTI clocks  :laugh:
Quote
Offline Fat Audi 80
« Reply #5 on: 11 October 2006, 20:58 »
Have you checked the coolant LEVEL? ;)
The best things in life are VAG
« Reply #6 on: 11 October 2006, 22:46 »
« Reply #7 on: 13 October 2006, 09:52 »
What connections are there that would cause that light to flash, are there any earths i'm possibly missing?
Quote
« Reply #8 on: 13 October 2006, 11:36 »
There is only the wiring to/from the temp sensor that could be causing an issue the fault must be there or inside the clocks...
Offline Coog
« Reply #9 on: 16 October 2006, 10:30 »
As mentioned above... could be coolant level. Had same problem yesterday
MK2 Golf GTi 16v
