Author Topic: clocks question  (Read 8136 times)
Offline workhorse '90 8v
clocks question
« on: 07 January 2004, 13:37 »
the girlys car still needs new clocks.
how hard/ is it possible to change the mileage ?
i've seen a set with 150k but her car is only on 115k
is it possible to rewind it?
Blue MK2
Re:clocks question
« Reply #1 on: 07 January 2004, 13:41 »
I would like to know myself.
I dont think you are allowed to rewind clocks or I would be doing it :P
You get the milage recorded on both clocks so that it doesnt effect the original milage.
Blue MK2
Offline Gozza
Re:clocks question
« Reply #3 on: 07 January 2004, 14:47 »
It is not dificult to adjust the mileage and I cant see why it would be illegal if you were changing the clocks to match the correct mileage of the vehicle after all you are not changing the history of the car, just the clocks !!
Blue MK2
Re:clocks question
« Reply #4 on: 07 January 2004, 15:44 »
I will look into that too. MOT is in july  :P
kidding ;)
Offline Gambit
Re:clocks question
« Reply #5 on: 07 January 2004, 16:16 »
hi-speed drill in the back of the clocks or on the end of the speedo cable- that way the digits are still properly alligned
just leave it running go for a cup of tea - check occasionally
its only illegal if you show less miles than are on the car
Re:clocks question
« Reply #6 on: 07 January 2004, 16:22 »
I know you can wind a clock on with this method.  But can you rewind it??
Are there no little things to stop the clocks being clocked?!
Offline Gambit
Re:clocks question
« Reply #7 on: 07 January 2004, 16:39 »
it aint possible to rewind it unless you take the clocks apart and move the digits yourself
otherwise technically driving in reverse would knock miles off your car!!
« Last Edit: 07 January 2004, 16:39 by Gambit »
Offline GTI16vGaz
  • New car will be displayed soon.
Re:clocks question
« Reply #8 on: 07 January 2004, 16:45 »
Your car is mint n i want the same 1  ;).... what wheels are they?
Offline Gozza
Re:clocks question
« Reply #9 on: 07 January 2004, 17:08 »
Thx mate, this is the car that cost me ?500  :-*
The wheels are O.Z Super turismo's although I feel the previous owner had a kerb fetish  :-[
Oh and to let you know, the clocks on the mark 2 can be dismantled and put forwards or back quite easily with a normal drill, using a simple method. You can take them apart and move the clocks individually I assume but they will then be out of line and would be a lot of hastle to put back together.
