Author Topic: clocks question  (Read 8155 times)
Offline Gozza
Re:clocks question
« Reply #20 on: 10 January 2004, 15:34 »
cheers gozzer. i can now source some cheap clock, excellent news, thanx..
No probs, drop me a message whe you have them and I will try to remember what I did, was a piece o piss, prob take you 30 mins depending on how many miles you adjusting by !!
Offline Dizzie
  • Make friends with your fast
Re:clocks question
« Reply #21 on: 10 January 2004, 17:03 »
you can wind the miles off with a drill, but you'll have to hold it on there. remove everything from the back of the speedo. this includes totally stripping down the clocks btw. take off the bit that the cable attaches to. this cunningly stops miles coming off when you reverse. you then should see teh cogs that count. by getting a pinion from an old RC car on your drill you should be able to wind them off. just remember to undo the face else the neddle might snap. I havent' actually tried this yet, but I'm pretty sure that's how it's done. I have a broken apart clock so if anyone wants me to I'll try it.
either that or remove the pin and set whatever miles you want on the clock.
« Last Edit: 10 January 2004, 17:04 by Dizzie »
