Author Topic: Suspension spring broken  (Read 3244 times)
Offline dodfus
« on: 06 October 2006, 21:25 »
Hello,
I was reversing out of a parking space today when on full lock there was a clank.  I stopped the car and turned the wheels from lock to lock and each time it went on full lock the clank appeared.  Jacked up the car to discover approx 10cm piece of the front passenger suspension spring had broken off.
Decided it was safe to drive home very carefully as the ride didn't appear to be affected too much.  Was this a mistake or can it not do too much damage.  How easy is it to fix.  Do I have to replace the other springs?
Any advice much appreciated!
Thanks
Offline GolfGL
Re: Suspension spring broken
« Reply #1 on: 06 October 2006, 22:59 »
Sounds a bit risky but they would probably be held down by weight if you went slowly. I think you should replace two front springs together as if ones gone the other might go and they other side will be more worn than the new spring. Might also be worth considering an eibach slightly lower and uprated spring kit for around £100.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline charri42
« Reply #2 on: 07 October 2006, 00:07 »
This happened to my 1.8T - exactly the same. i was actually quite relieved when I realised it was only the spring - made a hell of a noise. Apparently it is one of the mk4's many 'issues'
I was advised to replace both fronts. With hingsight I would have replaced with lowering springs (rears dead cheap to replace) as the OE VW springs cost about £50 each. I had the work done at a none VW garage.
Offline Flipmode
« Reply #3 on: 07 October 2006, 00:41 »
me too, rear ones had both cracked and needed repacing, cheap job tho so not to worry
Offline dodfus
« Reply #4 on: 09 October 2006, 12:35 »
Thanks for all the advice.  Does anybody know where is the best place to just get two replacement front springs from in the South East area?
Offline GolfGL
« Reply #5 on: 09 October 2006, 19:31 »
GSF, eurocarparts or vwspares all of them are competitive on price just watch out for delivery charges. links are on the golfgti homepage.
