Author Topic: Idle probs  (Read 1803 times)
Offline Tucker
Idle probs
« on: 05 October 2006, 22:18 »
Hi people,
1.5 carb
Been having a few probs on idle over the past week.
When cold she is fine, only when she warms up that it seems to have a misfire on idle. revs drop then back up. only about 100 or 200 revs. Just like flicking a light on and off.
I can give her some down the road with no probs
Seems to be getting worse, at idle only but an intermittant fault. sometimes sweet and sometimes not
Misfire and now sometimes the revs drop right down so the rev counter don't move but she still ticks over but then sometimes cuts out.
Sometimes would cut out and missfire but then back to norm for a few mins then same probs
I can sit there in traffic or at the lights just giving her a bit of throttle and she will have slight misfire at 1000 revs and no miss at 1500 up.
Bits changed:
Air Filter/Fuel filter/jet clean in carb.
Plugs/leads/rotor and dizzy cap.
Points changed last year
Help needed
Tucker
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline kraM
  • It's not the speed, it's the sudden stops...
Re: Idle probs
« Reply #1 on: 06 October 2006, 09:42 »
Hi
What carb are you running?
If it is a solonex carb, they have a little air bleed scree in the side that blocks up, causing it not to idle properley.  You can get to it from the drivers side of the car, remove it, clean it and replace.  If it works for a bit then goes back to poor running, you'll have to remove, strip, clean and re-build the carb.
Probably won't hurt to do the above any way, I its been done for a while.
If it is another brand of carb... I dunno, sorry.
Hope this helps
kraM
It's not the speed... it's the sudden stops...
Offline Tucker
Re: Idle probs
« Reply #2 on: 06 October 2006, 19:23 »
Cheers for the info chap, I have a peirsburg carb, the same?
cheers
Tucker
Offline richandhazel
Re: Idle probs
« Reply #3 on: 07 October 2006, 14:42 »
I have a Haynes manual for Solex and Pierbourg carbs. Which model is it and is it auto choke?
Offline Tucker
Re: Idle probs
« Reply #4 on: 07 October 2006, 17:55 »
Magic,
3B or PB, seen it on there somewhere.
Noticed it missing through out the range now, tried a mates coil with no joy.
Picking up a dizzy tomorrow, hope that does the job as they are known for going.
Daily diver too :rolleyes:
cheers
Tucker
« Last Edit: 07 October 2006, 20:12 by Tucker »
Offline Tucker
Re: Idle probs
« Reply #5 on: 07 October 2006, 18:01 »
Dho...yeah auto choke
cheers
Tucker
Re: Idle probs
« Reply #6 on: 08 October 2006, 00:19 »
Just got in.......will try and look when I get up in the morning :smiley:
Offline Tucker
Re: Idle probs
« Reply #7 on: 11 October 2006, 21:57 »
Ok peeps
Fitted a 2nd hand dizzy, set the timing and CO, dont cut out on idle now but lack of power and miss all the way up the range.
Started to puff blue smoke when you dump your foot :shocked:
Help. :cry:
Tucker
