Author Topic: idling? car wants to stall  (Read 2849 times)
Offline Jayy
« on: 03 October 2006, 19:51 »
Cars idling every now and then, revs go under 1000 and back up...like the cars going to stall? any ideas people?
Offline Flipmode
Re: idling? car wants to stall
« Reply #1 on: 03 October 2006, 22:56 »
could be several things, when do u get this problem, after the car been running a while or just when starting up?? temp gauage normal?? mine had probs starting or after re-starts eg. when getting petrol and it turned out to be the temp sensor, £15 fix, but my revs were moving upwards rather than down now i think about it.
Offline Jayy
« Reply #2 on: 04 October 2006, 20:45 »
it happens so randumly... could be when i start, when its out of gear at lights... when its coasting... jus kickins in when it wants really lol
Offline dave_drummer
« Reply #3 on: 10 October 2006, 10:32 »
throttle body! recond= £100-150
Offline Jayy
« Reply #4 on: 10 October 2006, 20:26 »
thats a bit much aint it! will this problem go worse? i changed to spark plugs the other day the easy to get to ones and it worked better for 2 days but its doing it again now, so im really confused now!
« Reply #5 on: 11 October 2006, 16:06 »
Like Flipmode said it could be any number of things.  To me it sounds like the throttle body.  Your best bet is to go down to your garage and get a diagnostic check.  That will show up any faults that may be causing the problem and save you time changing parts that donÂ’t need to be changed.
Offline Jayy
« Reply #6 on: 11 October 2006, 20:38 »
ok il do that then let you know, thanks!
Offline golf_turb0
Re: idling? car wants to stall... can any dubbers help????
« Reply #7 on: 12 October 2006, 10:41 »
I turn off my 1.8 t for a short period then it doesnt start for about 20+ mins sometimes and if i get it to  bump start  the idle is rougher & the revs go up & stays like it for about 10-15 mins drivin at low speed.. can any dubbers help?
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 12 October 2006, 11:57 »
The idle dips momentarily when the fans or aircon compressor kick in.
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 12 October 2006, 11:59 »
Possibly your temp sender mate, use the search function to look for temp sender issues and might be best to start a new topic so it doesn't get lost in this one :wink:
