Author Topic: Running components without the tweeter/crossover  (Read 2118 times)
Offline ItsHarry
« on: 02 October 2006, 09:10 »
Is this advisable? Im getting, hopefully, the Vibe SE-K6 speakers for the rear doors of my mk3 GL, can I run them without putting the tweeters in?
Would the stock tweeter that's already there (which I also believe has a built in c/over) be upto it?
Offline Len
Re: Running components without the tweeter/crossover
« Reply #1 on: 02 October 2006, 15:52 »
I've done the same thing! But mine are Infinity's in the rear doors. Been like that for over a year now so should be o.k. for you.
I do intend to put the proper tweetres and crossover in at some stage, just when I get round to it!
www.sas.org.uk
www.the-ace.org.uk
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #2 on: 08 October 2006, 12:01 »
You can mate as you will be driving its not gonna make a differance if the speakers are going in the back, especially the tweeters! You will need to fit the crossover though as you dont want your mid/bass driver picking up anything over 120hz which it will do if it has not got its crossover on it. The standard tweeter has whats called a capacitor on it, works the same as a crossover but cant take as much current, ie volume. The standard tweeter will be ok if your running your comp's off your head unit and not an amp. Dont worry if you have a high powered head unit, even a 4X50w will only be giving 18-21watts RMS.
