Author Topic: well the gremlins have appered  (Read 2094 times)
Offline daz123
« on: 30 September 2006, 22:10 »
car keeps cutting out after ten minutes can be driven again ? any ideas peeps
going to change the ecu relay 42 ? , if that don't cure i think a coil , can anyone shed any light
apart from that the car is great
vw want shoeing for this as i don't fancy it going work at motorway speeds  :cry:
Offline vwagain
Re: well the gremlins have appered
« Reply #1 on: 30 September 2006, 23:52 »
Replace fuel pump relay number 167 and ecu relay, number 30.
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline daz123
« Reply #2 on: 10 October 2006, 20:25 »
 :cry:replaced both relays but it cut out today , so i bit the bullet and ordered some software and a cable for laptop so i can drive around with it plugged in waiting for the fault to show up
Offline adyh
« Reply #3 on: 11 October 2006, 09:49 »
If there is a fault condition , it will show up when you read the codes , even if it is interrmittent.
Offline spankyVR6
  • better a seated piss than a standing sh!te
« Reply #4 on: 13 October 2006, 13:22 »
I know I keep posting about these, I make no gain other than trying to save people money, but if you just want to read/erase codes try one of these off ebay for a grand total of £25 http://cgi.ebay.co.uk/GS100-OBD-2-CHECK-ENGINE-SCANNER-CODE-READER-EOBD-OBD2_W0QQitemZ330035819118QQihZ014QQcategoryZ30921QQrdZ1QQcmdZViewItem. I got one about 2 months back and it has already paid for itself.
Offline V_Arse6
« Reply #5 on: 13 October 2006, 15:20 »
I've got one of those because I have an ABS issue..  But the stupid fecking thing doesn't want to read my ABS codes (you know how it does 3 sections - engine, airbags, and ABS).  Reads/clears Airbag/engine fine, but not ABS.  Works ok on my mate's VR6 though, so it's not the unit itself..  :cry:
Quite depressing really.  Still, Hopefully mr MOT tester won't notice that the ABS light and the airbag light go out at exactly the same time... ahem. :wink:
'95 Mk3 VR6
FK Highsports, Crystal Clear Fogs/Indicators/Repeaters, Mk4 Style Headlights, PiperX induction, Bonnet lifters. (Need to update pic for new headlights)
Offline spankyVR6
« Reply #6 on: 13 October 2006, 15:59 »
Oh yep, sorry :rolleyes:, I just keep presuming that everybody has later OBD2 cars as that's what mine is :rolleyes:.
I must admit I have used it an older pre '95 car and it didn't read the ABS (but did read engine and SRS). Good point.
I think the abs ecu must have been changed for the OBD2 cars.
How old/what reg is yours?
Offline V_Arse6
« Reply #7 on: 13 October 2006, 16:11 »
95 M.  I obviously just missed it.  :sad:  Ah well, like I said my ABS light does turn off now, so the system must be working fine..... *whistles innocently*.
In all seriousness, I do intend getting it fixed, and the fact that it's an MOT failure annoys me, since my brakes are otherwise perfectly fine (in fact better than fine - new discs/pads all round in feb/march this year).  stupid MOT laws... grumble grumble..
Hard to tell exactly what the system thinks the problem is without being able to read the ABS though.  I picked up an ABS pump off Ebay just in case it's that.  Supposedly it works, but even if it doesn't it still only cost 99p :grin:
'95 Mk3 VR6
Offline daz123
« Reply #8 on: 16 October 2006, 18:59 »
got the software and cable for 13 quid off ebay its vagcom , just gotta set it up right , cant wait to tap into it and see what it is , its also got revo , and some other system to alter your your ecu settings but i aint gonna go there  :laugh:
Offline gtitdi
« Reply #9 on: 16 October 2006, 19:08 »
have you had chance to try it out? if so is it worth the £Â£??
