Author Topic: Tapping or what?  (Read 1137 times)
Offline Malz0r
  • Haters gunna hate.
Tapping or what?
« on: 27 September 2006, 13:10 »
okay when i go up hill or the car is under load (normally just up hills) i get this faint tapping noise infront of me, but when you ease the accelorator it goes untill i put more power down? i searched the site found it may be tappets or is it something else? can i drive it okay for the moment? its not very loud but it does annoys the hell out of me, been doing it for abit a week so will it be okay for the moment? i hear valvers tap abit anyway? true or not?
anything helpfull would be great! Thank you!
Judderi
Re: Tapping or what?
« Reply #1 on: 27 September 2006, 13:48 »
It could be the timing chain. Over the years they get loose and make a noise.
Offline Len
« Reply #2 on: 27 September 2006, 14:36 »
Could be tappets/timing chain or possibly big ends!
www.sas.org.uk
www.the-ace.org.uk
Offline Stu.750
  • MMMMMMM Rust my favourite
« Reply #3 on: 27 September 2006, 14:48 »
sounds most probably tappets , does the tapping get faster if you continues to accelerate ,
 big ends are more of a rattle than a tap id have said
Judderi
« Reply #4 on: 27 September 2006, 15:39 »
My timing chain only rattled when under load. Bearings will do the same usually. Tappets seem to tapp all the time when dodgy.
Offline Malz0r
« Reply #5 on: 27 September 2006, 17:05 »
it stops tapping after you ge over 4k revs an it drives like normal a,d idle just fine only when pulling up hills?
Offline Stu.750
« Reply #6 on: 27 September 2006, 17:53 »
They are hydraulic tappets arnt they  ?
 if so it could be somethin to do with your oil level or oil pump , bottom end bearing rattle wouldnt stop over a certain revs
Offline Malz0r
« Reply #7 on: 27 September 2006, 22:56 »
oil was done less that 500 miles ago, so looks like tappets they dont do it much but will have some take a look to be sure :) thanks for your help!
Offline vwagain
« Reply #8 on: 27 September 2006, 23:44 »
1996 2.0l 8v, black magic pearl paint<br />
