Author Topic: Rev counter and speedo drop - momentarily  (Read 1645 times)
Offline richandhazel
« on: 27 September 2006, 04:08 »
Anyone had this? Driving along at a constant speed and for no apparent reason both the speedometer and rev counter needles drop down around 1/4 of the range and then pop back to normal. Its happened twice to me now, once about a month ago and the other around 4 months ago. Both times doing a constant 70 mph on clear motorway.
Not really too concerned just curious and hoping its not a sign of impending failure of 'something' :undecided:
Offline Rhyso
Re: Rev counter and speedo drop - momentarily
« Reply #1 on: 27 September 2006, 07:36 »
could it be a lead that's partly exposed and disrupting the signal to the clocks?  :undecided:
maybe the speed sensor on the gearbox?  :undecided:
« Last Edit: 27 September 2006, 07:40 by Rhyso »
Offline johntheboy
« Reply #2 on: 27 September 2006, 16:50 »
are you getting a loss of power with this aswel?
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #3 on: 27 September 2006, 19:27 »
Get Vag com on it, if you are losing power aswell it sounds like a coolant temp sensor
« Reply #4 on: 28 September 2006, 00:19 »
Nope, no loss of power, purely an indication problem.
« Reply #5 on: 28 September 2006, 00:22 »
I'm hoping to get some time to put VAGCOM on it tomorrow. I need to check for a possible turbo problem whilst I'm at it:- http://www.golfgtiforum.co.uk/index.php?topic=47660.0
