Author Topic: coolant fault  (Read 1515 times)
Offline chimp
coolant fault
« on: 26 September 2006, 17:03 »
hi chaps,
            can you help, im getting a coolant fault when i fire up my mk4 1.8t. it says STOP service manual. when i turn off engine and restart it the fault has gone. its happening nearly evertime i start it and its driving me mad. the engine temp is always normal and the car seens to drive ok. the stealers changed one of the sensors not the headr tank one the other but to no avail when i put it back in they said there was no fault showing. could it be anything to do with the climatronic. :cry: :sick:
The golf is an object of admiration
Offline Rhyso
Re: coolant fault
« Reply #1 on: 26 September 2006, 17:09 »
I'd try changing the sensor in the header tank first.
hopefully that should cure the problem
Offline chimp
Re: coolant fault
« Reply #2 on: 26 September 2006, 17:22 »
i will give it a go. do you have to change the whole header tank or can you just change the sensor.
Offline Rhyso
Re: coolant fault
« Reply #3 on: 26 September 2006, 17:24 »
i think the sensor is part of the cap so no need to change the whole tank  :smiley:
Offline Flipmode
Re: coolant fault
« Reply #4 on: 27 September 2006, 20:13 »
CHIMP.....
i have the same problem in my 1.8t, can u let me know how u get on please inc how easy the fix was, ho wmuch cost etc ??
cheers chap, i'd say on 50% of my start ups the bloody light comes on and beeps at me, know what u mean about it being pain in the @rse
Offline chimp
Re: coolant fault
« Reply #5 on: 28 September 2006, 14:20 »
ok , ive got it booked in next week will see how it goes and hopefully let u know.
Offline Flipmode
Re: coolant fault
« Reply #6 on: 28 September 2006, 20:43 »
thanks,
will keep an eye out for your news   :smiley:
Offline chimp
Re: coolant fault
« Reply #7 on: 16 October 2006, 16:27 »
had the header tank sensor changed and so far all is el lushio, i think ive cracked it
Offline Desperado2
Re: coolant fault
« Reply #8 on: 16 October 2006, 16:43 »
Can you let us know the end cost?
I get this occasionally also on the 1.8T. I've just been ignoring it as it normally goes out within a few moments.
Offline chimp
Re: coolant fault
« Reply #9 on: 18 October 2006, 16:19 »
the part cost £8.50 cheap like the budgie, garage fitted it charged  £33 all in.  :smiley:
