Author Topic: Replacement charger for a G60 ?  (Read 846 times)
Offline Uruk Hai
« on: 25 September 2006, 12:49 »
I've been offered a Corrado G60 and it needs a new charger, does anyone know how much they are ? I can get it fitted no problem, also when the chargers go bang do they take anything else with them or is it just a case of a straight swap, any help appreciated  :wink:
Offline topher
  • Administrator
  • fully functioning
Re: Replacement charger for a G60 ?
« Reply #1 on: 25 September 2006, 13:45 »
depends what happened to the charger. if it exploded and sent bits of metal through the engine then you're in a whole heap of trouble. if its just worn beyond the realms of a rebuild then a replacement blower will do fine. try darren at g-werks he either has some or knows where to get one most of the time. there are other options to the g-lader though.. eaton.. lysholm... or ihi turbo :grin:
Offline Uruk Hai
« Reply #2 on: 25 September 2006, 21:42 »
Thanks for the reply, the car drives fine and apart from the rather large loss of power everything seems to be O.K., the engine sounds fine.
